adrewpower
Drew
F150 & Bronco
Saw another thread talking about doing a forscan update to make the LED taillights replace the base taillights. Anyone know how or where that setting is located. Didn’t see it on the spreadsheet.
Thanks in advance.
isaacfinnegan
Isaac
Hawaii
Thanks in advance.
If you are replacing your taillights and changing from LED -> regular or the other way you have to adjust the settings in forscan because there's a different # of lights in those different models. Same for the Oracle flush mount lights (which I have).
They aren't detailed in the sheet, becuse you cannot change them without also changing the hardware parts. What you change is detailed in install instructions.
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
Someone should provide this as a service. Seems like it be an easy $200 for 30 minutes of work. Seems a waste for me to buy a MS Windows machine, get the Forscan software and the connector then do the changes and then everything is put away to never be used again.
I got it to make my changes, but I licensed it to make changes for buddies, I have ended up using it on several vehicles for several reasons. The best was adding remote start to my super duty. Maybe you can find someone locally that would be willing to help you out.
Hatman
Argyle, Texas
Badlands Sasquatch 2.7L
I have a 2023 obx with lux an sas package. Is it possible to add additional goat modes ex. Baja rock or change the headlight halo to amber color with forscan ? Is there a list somewhere if available changes with forscan for Broncos? Thanks for any insight
Yes all of those things are possible in Forscan. You should try to find a local Bronco group and I’m sure someone there will be happy to help you out. I do it for others in the North Texas Group.
Ron B.
Ron
West Hills
Mustang
I had Panda Motor works do my Forscan changes remotely. It was worth every penny took minutes and the cost is minimal. You will watch them do changes so in future will make it easier to do it yourself. Thank you Troy at Panda Motor
Bronc’n Bronco
Kevin
Washington State
2023 Bronco
That’s interesting. Do you have a link to them?
GI_Jo_Nathan
Jonathan
EvenBiggerN8
Nathan
Anchorage, AK
23 Bronco
6. Is there a way to make the last used GOAT mode auto select everytime you re your vehicle? Seems no matter what mode I am in, if I stop the engine and then restart, I have to reselect the Last Goat Mode I used. As a result, now I just keep my engine runnning most Of the time, unless I am running or wanting normal mode. In other words, when you restart it always goes back to normal mode.
[/QUOTE]
Did you ever get number 6 answered
SAVEUP
Russ
Lake Texoma
2019 Explorer
Was wondering the same thing.
If so, what did you use to active the remote start? The Key Fob does not have the button and the Ford app does not either.
Ctal
Pa
2023 ford bronco
Has anyone recently tired to enable remote start with 7-speed?
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
I searched but did not find an answer. Is it possible to disable the speed lock out for Sync? It would be nice for the passenger to swap phones or search for a business without pulling over.
BlarneyStoned
Apple-at-cha
Saleen
So I've noticed that if there is something heavy enough to be detected as a person, or someone sitting in the passenger seat, that they can access things like the destination search or phone list while the vehicle is in motion but if there is nothing in the passenger seat those functions are completely disabled.
CARdiac
Joel
Maryland
Thanks, even with my 225lbs in pass seat there is very little that can be done.
Fly
MA
Subaru Outback
I did the amber DRL mod but every time I start the bronco it defaults to auto for the headlight switch position. Is there a way to remember last setting if I wanted to leave all lights off?
