Form Lighting headlights hardware revision?
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I received my Form Lighting headlights and taillights yesterday that I ordered during the Black Friday sale. I installed the headlights this morning, and I noticed that mine were slightly different than the ones that the installation video and guide show. Specifically, the connector that controls the color of the DRLs is built into the headlight assembly. I don’t have a separate wiring adapter. Also, mine are amber when the connector is plugged in, and white when unplugged (opposite of what the instructions say). Finally, mine didn’t come with the drl amp connectors (which is fine because my Bronco has factory DRLs). Maybe this is already known, but I hadn’t heard of any hardware changes, so I figured I’d make a post.
murrman
murrman
Sean
Toledo, OH
I wonder if they fixed the giggling of the projectors too while they were making changes....
I haven’t heard of this issue, can you elaborate?
Ducati1098
Or the flickering LEDs they have problems with.
I’m having a set warranties right now, so hopefully these will be better 🙄
TLO
Canada
youtube.com
2 door
Yeah, I had one replaced for a halo going intermittent. New Bronco on the way but I think I'll stick with the factory LED's...
Incandescent tail lights HAVE to go tho!
Destination Bigfoot Bronc
Jamie
Richmond, Virginia
2019 F150 Limited, 2022 Bronco OBX Cyber Sasquatch
I can confirm all these changes with my warranty replacements, due to headlight housing crazing. The projectors no longer jiggle while driving and the start-up sequence now pulses(or breathes) for a few seconds after the headlight sequence finishes. Along with all four projectors being used for low beams instead of the top 2. Headlight output seems much improved with a sharper cutoff line. We'll see how long the polycarbonate UV coating lasts with this set
B A C N O W
Bryan
SoCal
Nissan Titan Pro4x
Please keep us updated (in the future) on any durability/quality issues! Hopefully they have worked out all the bugs in this updated version of Form’s headlights!
