Ford Performance Tune Dealer Install Issue
Sk3tchy
Paul
Maryland
2023 Bronco
TLDR; No shops will install the tune.
Ok, so, I was interested in getting the Ford Performance Tune for my 2023 Bronco Wildtrak Sasquatch. Obtaining the tune is no problem; the problem I have encountered in that I cannot find a dealer that will do the install for me. I live in Maryland and have called no less than 10 dealers, many who are Ford Performance shops. None of them will do the install. One forwards me to another, then that one says they will not do the install. The next says the same thing, and it is a never-ending circle of failure.
My question is this: Has anyone else had this much difficulty in finding a Ford dealer to do the actual install? And if you are in Maryland, any suggestion of a dealer that will perform the install?
Thanks.
I believe you can use any ASE mechanic and it will preserve the warranty. So you can go outside of Ford Dealers.
I don't know why they stipulate that, there's nothing at all about the installation that is even remotely difficult or technical - you don't have to change any parameters or program anything, you just need a laptop with an internet connection. But it is what it is.
Aonarch
Jack Hoff
MT
You can use any ASE mechanic and it will preserve the warranty. So you can go outside of Ford Dealers.
This.
"ASE Red Seal" certified.
Or just do it yourself.
RagnarKon
Ford Bronco, Escape, Focus
My dealer ended up doing the install for me, but at the time there was a 3 month wait for an appointment... so I called four other dealers in my area. Three of the four said it was a service they did not offer. The fourth said they would do the install, but they have a policy to not install customer-provided parts and I would have to buy the ProCal tune through the dealership. So I definitely understand the issue you are encountering.
As others have said, any ASE (or RSE, for those in O' Canada) certified mechanic can do the install to retain the warranty. So if you have a 4x4 or performance shop nearby, definitely check to see if they can do the install for you.
Silver-Bolt
Eureka, MT
The dealer makes money selling you the tune, not on the install. See if you can buy it from the dealer you want to install it. They likely will be more receptive. It will cost more than buying online but you won't have to worry about warranty issues.
Sk3tchy
Paul
Maryland
2023 Bronco
This.
I'm a cyber security analyst, and could do the install myself, however, I do not feel like losing the warranty in the process. That is why I asked the question. So, I guess I will search out an ASE technician.
Thanks.
Aonarch
Jack Hoff
MT
Thanks.
Ehh. To each their own. I doubt Ford would void your warranty down the road flashing it yourself. Somehow incorrectly flashing it won’t cause something to break down the road. It is their tune file.
Ford just uses it as a way to drive people to dealers for some cheesy install money. And an easy way they can back out of warranty claims.
Overcooked
WA
2023 2D WT, 2021 BMW 540, 2024 BMW M8, 2021 X7
Ford dealers near me are happy to install mine, one of them even encourage me to get one myself because it would take them too long to get the part, this was from the parts guy so I guess he was just lazy lol.
Sk3tchy
Paul
Maryland
2023 Bronco
Thanks for the replies everyone. I will just find an ASE that will do the install.
userdude
Denton, TX
2023 2dr Badsquatch
Most definitely my dealer made a couple hundred off my install, minimum. That's paying the tech, too.
Dorf2point0
Richard
Anchorage, Alaska
2022 Explorer, 2005 Explorer, 2013 Escape
This is not Rocket Science, Ford made this Tune and it has a Ford P/N.. It’s not going to hurt your engine, just requires you to use High Octane gas .. Using high Octane gas with the Tune is like putting a “tiger in your Tank”.. The tune requires a PC.. This PC should be yours, not the Dealers.. You can store your original tune that was installed at the factory, so if and when you remove the Performance Tune, you have a copy of the original.. Dealer doesn’t do that obviously.. As I have found here is Alaska, most Ford shops never know you Tuned it unless you have a sticker on the hood or the box with the Ford Performance Tune in your glovebox . GO forth and TUNE.. Save you original programming on YOUR PC.. 🤓 oh YES, I have been a Rocket Scientist 🤣
Nickhick
Nick
Bath twp ohio
F150 xtr, vw passat
Thanks.
Dude. The dealership I bought our Bronco from was the only one that would install it just because of my relationship with the salesman. I called every dealership and every aftermarket shop they referred me to. None would install. They all said the same thing. The installer is on the hook for any warranty issues and it's not worth it for them. Had to drive 1 1/2 hours away for installation. How can Ford sell a pard that Ford won't install? That being said, the time is TOTALLY worth it. 🍻
GI_Jo_Nathan
Jonathan
For what it's worth I had mine installed by a Lincoln Dealer. I don't like my local Ford Service Dept.
