- Doug
- Jun 23, 2024
- 34
- 1,584
- 3,756
- Washington
- '24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
- Wildtrak
I hear you. I have no problem dealing with nuts and bolts or mechanical issues, but the Procal challenges are probably beyond my patience and capabilities to resolve should I run into issues. I too would like to find "sure fire installation" instructions, but I have yet to find it. Seems almost random that install goes smoothly for some and turns into a computer flash nightmare for others. I have a '22 WT, I'm hoping that is a helping factor since they were going to roll the HD rack into production shortly after mine was built.It’s In the install process. In my mind it should not make a difference but in this case following the install instructions might be worthwhile. And since I am not a Ford software engineer and do not have access to the code I can’t give you the bottom line details. Sorry For that.
if you can do a favor and post the installation instructions in this thread that would be great.
Thinking out loud, mechanically it’s not a problem the issues come up with the programming side Like SHURDBA is experiencing. The computer code for the vehicle is quite complicated and it must be pretty difficult for Ford to keep track of the status of every vehicle that has been changed from original/as delivered and as updated by Ford updates for every Ford vehicle. It’s one of the reasons that I stay away from Forscan (Russian hack program) Or aftermarket performance tunes.
