Ford Performance Severe Duty Steering Rack Install + Programming Experience (Bay Area)
robo
Rob
Santa Clara, California
2012 Subaru STi hatch, CG 2022 Badlands Sas
Back in March 2024, I purchased the Ford Performance Severe Duty Steering Rack.
Since I already had the Ford ProCal (Pro-Tune) device, I figured I'd save a few bucks and use it to program the rack.
A couple of friends went with pre-programmed racks from BroncBuster, and their installs were completely plug-and-play. No issues at all. Meanwhile, as I researched doing mine, I kept seeing post after post about programming problems. That was enough to make me hesitate… for a long time. The box ended up sitting in my bedroom for over two years.
Dealerships didn’t want to touch it. Even a local Ford Performance shop declined the job.
Then came Pop's Tire Shop in Fremont, CA.
Lo (the owner) is a friend and part of our Bay Area Bronco community. His shop mainly does tires, wheels, and alignments, and he always takes care of us—especially after trail runs. He’s got both an alignment rack and a full automotive lift.
We had talked about installing “the rack” before, but I wasn’t confident. On a recent visit for an alignment, we brought it up again. This time, Lo said he had successfully installed and programmed his own severe duty rack and felt confident he could handle mine.
So I brought it in.
Day 1: Rack installed with no issues.
Day 2: Programming problems. The voucher showed a download should be available, but when we connected the ProCal device, there was nothing there.
The next 7 days were spent trying to get a new code from Ford Performance Support. We kept getting routed to the same rep (“Tom”). Whether he was overwhelmed or just not equipped to resolve it, the process was extremely frustrating. He mentioned sending emails that never arrived, and we basically made zero progress.
Meanwhile, my Bronco was tied up on the only lift in the shop.
Lo and I started discussing worst-case scenario—putting the stock rack back in. He even told me he wouldn’t charge me if it came to that. So no upgrade for me, no payment for him. Lose/lose.
On the final day, Lo and his team went full persistence mode—taking turns calling and hitting redial until they finally got someone on the line. This time, we got the correct code.
The download finally worked. Program loaded to the ProCal device… then into the rack.
SUCCESS.
Huge relief all around. But honestly, it shouldn’t have been that difficult. It's a code. It doesn't cost Ford anything.
After everything, I asked Lo if he’d be willing to take on another one of these installs. His answer: “Yeah.”
So if you’re in the Bay Area and you’ve got one of these racks collecting dust, there is a path forward.
Wilbur's son
Hesston, KS
2001 Ranger 4x4
The Ford Performance/Ford Racing Parts website says that the Pro-Cal has to be connected before removing stock steering rack. Is this still true? And then you uploaded the new code program to setup the HD rack? I've looked at this upgrade for years now. Thx
This seems so much easier if you just go the Forscan/FDRS route and not fool with ProCal
robo
robo
Rob
Yes, you do need to hook up the tuner while you still have the stock rack installed.
Our problem came in getting the new code program from the Ford website onto the tuning device.
robo
robo
Rob
I've used ForScan for a few things and was getting ready to research using for this application as a work-around. But we got what we needed before it came to that. Good to know there's another option out there where you DON'T need to deal with Tom.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I've been in the exact same boat, but mine is sitting in the basement. I recently learned I can leave the OEM rack in place, wiggle the new rack in under the truck, swap the connections, and then try to program. That will be my first approach since I have the calibration loaded on my Procal. If that tanks, the yet to be defined Plan B programming approach will be in acted.
robo
robo
Rob
Nice!
Since you already have the new calibration loaded on the ProCal, you should be good.
That was our big battle.
shurdba
Encinitas, CA
2022 Bronco 2 Door
Same exact story happened with my installation. Was on the phone with the same Tom for 29 days begging him to give the tech the secret download. My saga is posted.
robo
robo
Rob
29 Days!!!!! Holy crap. You nearly tripled my 10 days on the lift
It’s just software! Why can’t he just give it up right away?
Built2Wild
Bay Area
Motorcycle
I had the same issue but my install was done at a Ford dealership. It took them a week to get the job done. Ford Performance is a challenge to deal which why some have gone with the Broncbuster install instead.
Grant3168
Grant
Denver, Colorado
2013 G37, 2006 G35
On my local bronco group, some guy had the same issue. He had it at a Ford Dealership for months before they finally were able to finalize the software update for the new rack. That has scared me from doing the same to my bronco. It really shouldn't be that hard.
robo
robo
Rob
Yup, That's why I sat on it for so long.
But I haven't read of any failed installs, just might take a while if there are issues.
FP Customer service def needs major improvements
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I still want to do this. Galpin up in LA quoted me $3200 to do it, but I'd really prefer someone local to San Diego.
shurdba
Encinitas, CA
2022 Bronco 2 Door
It gets better. After the 30 day install at the dealer, I went to the UBB event in Utah and on the first day my four wheel drive failed. Kept popping up disabled. Was done after the first day. Was pretty sure it was the SSM 51212 for 21-22 bronco with 2.7 drive train. Dealer installed the software update for the ABS. Still throwing the error when wheels are rotating at different speeds. Now, the dealer suspects the steering rack install has something to do with the four wheel drive problem. More to be revealed.
Good news is the steering rack didn't fail while being dragged through a level 6 trail in 2 wheel drive.
robo
robo
Rob
Yikes!!
I hope you can get it resolved.
Bummer it messed up your UBB experience, but that terrain will def test your rig.
Be sure and update us when you figure out what the problem is.
