Ford Performance DIff Cover paint chipping
jsoa
Jose
Delaware
2024 Bronco 4dr
Anyone else's FP diff cover paint chipping away?
Ford Bronco Ford Performance DIff Cover paint chipping PXL_20250303_132747730
Ford Bronco Ford Performance DIff Cover paint chipping PXL_20250303_132808958
Wonder if I just got a bad one or if this is common.
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
JT58Bronc
JT
Fl
Yes, I had paint chip away the day I installed it- around some of the bolt holes. I touched it up with paint that I had at the house that was almost a perfect color match. I used a small brush around the bolts. I was not too happy about the paint chipping. I have not had any more chips occur since the install.
mjp2
2021 Cyber Yellorange Bronco Badlands
Same experience here with the paint chipping around the bolts during installation. I left it alone as I installed for the drain hole and wasn't concerned about the cosmetics of it.
That said, I coated the underside of the truck with Blaster Surface Shield so the missing paint shouldn't lead to rust issues unless I missed a spot.
snolen
stan
indiana
78 bronco
mine looks the same but i am in the salt belt noticed mine last week also paint was chipping on the install also rather disappointing 🤷‍♂️
Ducati1098
Yep mine looks the same. Eventually I'll remove it and have it powder coated
Ninjak
Miami
I have a paint chip, a section came off. I will eventually get around to painting that spot.
JT58Bronc
JT
Fl
Looking at the chipped paint, the metal underneath appeared rusty- like no primer was used before they applied the paint. I sanded the rusted areas before I applied the touch up paint.
broadicustomworks
Hanging Rock, North Carolina
This is concerning for those who I've painted Diff covers for (including myself).
IF there was oxidation under that factory paint that eventually leads to coating cracking and delamination, then the "pretty" stuff on top of that inferior coating isn't going to prevent it from happening. Slow it down, sure.
Keeping fingers crossed this isn't a widespread situation...
Ninjak
Miami
It does look like rust where my paint chipped. I will do this as well when I get around to fix this.
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
Mine started chipping more
Ford Bronco Ford Performance DIff Cover paint chipping PXL_20250313_122212082
Also, fwiw, I emailed FP about and they are sending a replacement (might just get that new one powder coated from the start)
615_Bronco
Cheatham, TN
2022 Bronco 2D BL, SAS, MT, & 2015 F-350 DRW
Mine looks just like that and its only been on for 4-5 months
Ducati1098
Mine doesn't look quite that bad, but it seems that it's only a matter of time.
I sent them an email too to see if they'll send me a new one 🤷‍♂️
Ford Bronco Ford Performance DIff Cover paint chipping IMG_6841
615_Bronco
Cheatham, TN
They sending some of that expensive Motorcraft oil too with the replacement covers?
JT58Bronc
JT
Fl
Oh boy those look awful. I stated it in another post, it seems they missed priming before they applied the finish coat of paint. I have painted a lot of auto parts and if you don't use good primer base, this is what happens.
