Fog lights: Amber or Clear?
VictoryLights
Pittsburgh
2018 Honda Pilot
Yes. Amber on one switch, white spot/trail on another. Kit comes with wiring harness to separate the two
I want to do this, but hate how it eats up two aux switches.
Brad Fx
U.S.A
Jeep Commander
Note: The amber color is just a backlight feature and not the main beam (accent lighting)
If you have any other questions, we'll be glad to help!
@Diode Dynamics Hi John. So in this pic the SS3, 2 SSC2s, and the SSC1 are all white and just have the amber backlight on? The SS3 and SSC1 backlight seem so much brighter than the SSC2s. Is there a difference in Sport, Pro, and Max “backlight” brightness that causes this? No big deal, but it would be cool if possible to have all 4 of those lights with the same backlight brightness. Thanks!
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Ahh. There are still 4 more. And it makes them easy to use and it's nice to have them work independent of each other, as I don't always need both as they serve different purposes.
mountainbronco
Way too many choices. I want a-pillar white spots and bumper amber wide fogs. Whoever makes my decision easiest gets my business. I have the aux switches.
AUXBEAM Pod ditch spots up top in white, and Diode S6 6inch amber SAE fog in the bumper.
I use the bumper fog as a second running light all day long. Traffic sees me, and no blinding oncoming. And, it looks great!
Ford Bronco Fog lights:  Amber or Clear? 20220130_110305_LI
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
All of our backlights are the same brightness.
The angle at this image was captured impacted the flare of the backlight on the SSC2 LED pods.
Ford Bronco Fog lights:  Amber or Clear? IMG-4072
However, the TIR optic installed on any pod will determine the vibrancy to a degree.
For example, the SSC1 has the flood optic which disperses the backlight the most out of all of our optic choices.
Tinman
Fred
Wellington
F -150
Hey there!
The image featured here is our SS3 (Stage Series 3") Pro LED fog light kit with our SAE-compliant fog optic. These kits are 100% plug-and-play.
Our SS3 LED fog light kit is offered for most vehicles in our SS3 Sport, Pro, or Max power level in 6000K cool white or 3000K selective yellow.
Our SS3 Pro option is 2x as bright as our SS3 Sport. However, the brightest option the SS3 Max is 40% brighter than the SS3 Pro!
Now compared to other options on the market. We use patent-pending TIR optics to focus the light in a highly strict beam pattern.
It's important to note this kit is available for the standard bumper:
Image courtest of LightWerkz featuring our SS3 Max LED fog light kit
Product Link: https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2021-ford-bronco-w-standard-bumper.html
If your Bronco is equipped with a modular bumper, you would want to check out our Stage Series Fog Pocket Kit for 2021 Ford Bronco!
Read more here: https://www.bronco6g.com/forum/thre...onco-diode-dynamics.24428/page-4#post-1046714
Product Link: https://www.diodedynamics.com/stage-series-fog-pocket-kit-for-2021-ford-bronco-w-steel-bumper.html
Do you know if the backlights on these can be wired in with the stock headlights? so if the headlights are on so are the backlights. Not sure if it would set off an error or something.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I have these…planning to install after work today! 👏🏼
5280Bronco
Denver
I have the same setup and love it.
Ford Bronco Fog lights:  Amber or Clear? PXL_20220208_034940763~2
WarthogJr
'21 Bronco Black Diamond
Ford Bronco Fog lights:  Amber or Clear? 5E5F8162-1D58-49F4-A115-8D836E26163B_1_201_a
We were at the hammers last week. I've never seen that much dust in my life. The ambers are the only thing that have a chance in that muck. The a-pillars were too high, but the ambers down low worked much better. (No, I don't have fogs on the side of my ride...weird camera thing I guess?)
Ford Bronco Fog lights:  Amber or Clear? 05C2EFEA-3169-4CA5-A9C4-D0219C0E6817_1_201_a
ex_nyer
Chokes
Connecticut
F150, Land Cruiser, Outback
Is that the Baja Designs Fog Pocket Kit with bezel? If so, how do you like it? I'm leaning heavily toward that product.
SAME!
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
What brackets did you use?
