Fog lights: Amber or Clear?
fv9
Camas, WA
2018 Alfa Romeo Giulia Ti Sport, 2005 Lotus Elise, Protoform P3 formula vee, Crossle 32F formula ford
not mine, but cropped img from diode of why I’m going Amber
What’re the size of those amber lights? Perhaps I’m wrong, but I can’t imagine two of those small ambers in the bumper pocket casting out that much light.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
@Diode Dynamics , how would it look with the Bronco?
According to their IG, it's a SS3 for a Tundra
  • Like
Reactions: fv9
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Hey there!
The image featured here is our SS3 (Stage Series 3") Pro LED fog light kit with our SAE-compliant fog optic. These kits are 100% plug-and-play.
Ford Bronco Fog lights:  Amber or Clear? 1642093548211
Ford Bronco Fog lights:  Amber or Clear? 1642093557068
Our SS3 LED fog light kit is offered for most vehicles in our SS3 Sport, Pro, or Max power level in 6000K cool white or 3000K selective yellow.
Ford Bronco Fog lights:  Amber or Clear? SS3_Yellow_LED_Pod_Wall_Output_Collag
Ford Bronco Fog lights:  Amber or Clear? 187385485_10225999264269051_6575675642040914203_n
Our SS3 Pro option is 2x as bright as our SS3 Sport. However, the brightest option the SS3 Max is 40% brighter than the SS3 Pro!
Ford Bronco Fog lights:  Amber or Clear? LED_Pod_TIR_Optic_Forum_Graphic
Now compared to other options on the market. We use patent-pending TIR optics to focus the light in a highly strict beam pattern.
Ford Bronco Fog lights:  Amber or Clear? IMG_5012 (1)
It's important to note this kit is available for the standard bumper:
Ford Bronco Fog lights:  Amber or Clear? Milton Hughes SS3 Fog + Ditch
Ford Bronco Fog lights:  Amber or Clear? 147147136_3833184590038362_3735534625593680105_o
Image courtest of LightWerkz featuring our SS3 Max LED fog light kit
Product Link: https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2021-ford-bronco-w-standard-bumper.html
If your Bronco is equipped with a modular bumper, you would want to check out our Stage Series Fog Pocket Kit for 2021 Ford Bronco!
Ford Bronco Fog lights:  Amber or Clear? Untitled-1
Ford Bronco Fog lights:  Amber or Clear? IMG-4196
Note: The amber color is just a backlight feature and not the main beam (accent lighting)
Read more here: https://www.bronco6g.com/forum/thre...onco-diode-dynamics.24428/page-4#post-1046714
Product Link: https://www.diodedynamics.com/stage-series-fog-pocket-kit-for-2021-ford-bronco-w-steel-bumper.html
If you have any other questions, we'll be glad to help!
GToddC5
Todd
South Jersey
www.bronco6g.com
Hey there!
I'm loving the backlight feature, how are they powered? Assuming each main beam pair can be powered by individual upfitters, so I'm wondering how and when the backlight features can be on?
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Backlight Functionality. Each pod in this kit includes a distinctive Amber backlight feature that can be controlled separately using the factory aux switches. The backlight on each pod included with the kit fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Separate Switches. With the included harnesses, the two SS3 pods and four SSC2 pods on this kit can be controlled independently using the factory aux switches, allowing you to switch between road-legal fog lights and offroad lights with ease. If your Bronco doesn't have a factory aux switch bank, you can pick up an extra wiring harness to control it using a toggle switch.
*There is an internal override that will turn the backlight off when the main beam is flipped on.
We will be including specific wiring harnesses for the Bronco included with our Stage Series Fog Pocket Kit for 2021 Ford Bronco.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Way too many choices. I want a-pillar white spots and bumper amber wide fogs. Whoever makes my decision easiest gets my business. I have the aux switches.
GToddC5
Todd
South Jersey
www.bronco6g.com
Great info, thanks. Is it safe to say that all of the SS3 LED pods are street legal? (Sport, Pro and Max)
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Great question!
Our SS3 LED fog light kit for the standard bumper is street legal for on-road use in all three power levels (sport/pro/max) when using our SAE-compliant fog optic.
It's important to assure they're adjusted and aimed properly during the installation process.
As for the Stage Series fog pocket kit for the 2021 Ford Bronco. The SS3 is legal for on-road use and the outer SSC2 LED pods are for off-road use.
Ford Bronco Fog lights:  Amber or Clear? 1642105240573
John C.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
If you need immediate assistance, give us a call at 314-205-3033 M-F CST, and our service team will be happy to help arrange the custom setup you're seeking in minutes.
GToddC5
Todd
South Jersey
www.bronco6g.com
Great question!
John C.
Diode Dynamics
Great info, I'm much closer to pulling trigger on the pre-order now. The backlight is just too damn sexy! I just need to figure out the highest power level I can go, without pissing off oncoming traffic (SAE Compliant or not, I don't want to be one of those people annoying others with too bright a fog. I will be going with the amber fog, for sure. Thanks again.
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
If you end up going with the SS3 Max, you will not have concerned with being flashed when aimed accordingly.
However, it's important to note if your vehicle is lifted compared to the factory height you may need to aim them down a bit more.
I am personally running the SS3 Max LED fog light kit on my daily driver and haven't ever been flashed since my initial installation 9 months ago.
Ford Bronco Fog lights:  Amber or Clear? LoLVcsi
John C.
Diode Dynamics
JohnnyBronco
Pennsylania
X4
https://offroadalliance.com/Baja-De...AE-Fog-Pocket-Kit-21Up-Ford-BroncowUpfitter-/
They were out of the one with the upfitter wiring pack built in but had the wiring harness kits for them separately that could be sold with the kit and worked great for tying them into the upfitter switches in the bronco.
Just clicked on that and in a popup CJ Pony Parts has exact same for $137 less
Correction, the popup shopper lies. CJ Pony Parts either has not updated their site or ETA of August means 8 months from now?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Just head to our site where we offer plenty of kits:
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
If you get one of our kits with the KR Off-Road brackets they ship RIGHT AWAY as well, and you can fit larger lights AND you can adjust them more.
We're also the only ones (that i'm aware of) that are offering Diode Dynamics fog kits since we make our own brackets.
We're also here in NY so we're 1 day shipping to you in PA (did I mention we make the KR Off-Road brackets here on Long Island?)
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
John C.
Diode Dynamics
Wow! I just ordered these in the Pro version and if they’re anywhere as close to the visibility here I’ll be thrilled. 👋 @GToddC5 we’re having the same thoughts here bud hope all is well
GToddC5
Todd
South Jersey
www.bronco6g.com
Only 4 more months till my first week down the shore, hope we get a chance to hang out and show off our rigs! 🍻
