Flat tow battery disconnect
Bronco2023?
Fish
09 Chevy, 15 Jeep
So I have been reading alot of threads. About flat towing. It seems to me their is a simple way to stop the trans and transfer case failure. Get system into flat tow mode then just disconnect the battery's no way for electric system glitches no way for system to default. Am I missing something seems simple. I would rather reset radio then pay for new trans.
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
That was discussed early on. It specifically states in manual to not disconnect battery. It can possibly lead to problems when you arrive at destination and reattach battery. I sure wish it was that easy.
Bronco2023?
Fish
09 Chevy, 15 Jeep
Thank you hadn't seen that. It seems so simple. Computers phones etc turn on and off everyday. Don't see see why the Broncos system would be different 🤔
Bronco2023?
Fish
09 Chevy, 15 Jeep
I was looking at the road master disconnect system
dgorsett
colorado
F250, Mustang, Explorer
Your idea would work if the problem is that the Bronco shifts out of neutral tow somehow during the tow. It has not been shown that this is the problem. I think it might be inadequate disengagement of the AWD clutch when in neutral tow. Ford has not been forthcoming in acknowledging the issue.
Small issue, but I use the Bronco battery to power my RVI brake. It could be powered by an auxillary battery though
Bronco2023?
Fish
09 Chevy, 15 Jeep
I have demco air brake system. So one one in flat tow. I would guess everything would be disengaged. Disconnect battery and nothing could glitch. As far as I know there is now backup battery in any systems
Bronco2023?
Fish
09 Chevy, 15 Jeep
Hello so I was looking at the Chevy flat procedure. And they tell you disconnect the battery once in flat tow. This has my brain spinning what the difference is between the Ford and Chevy. Wondering why the Ford would lose it memory and Chevy wouldn't.
Ducati1098
Totally different parts and everything, so I’m sure they’re controlled differently
Bronco2023?
Fish
09 Chevy, 15 Jeep
Also on other note my 23 Bad land had transfer case go bad in 18000 miles. Makes wonder how hve had problem and didnt know it. Then flat tow and it blows up the trans. Would have liked to open it to to we what happened. But Ford said just replace it
