Flat/flush center dash mount?
Nc211
Washington DC
I’m trying to find a flat mount for the center dash mounting point, maybe the size of say a silver dollar. I want a place to velco down a bobble head (actually Hula girl) on the dash board. Everything I see arm for telescoping arms (phone holders) and heavier usage. Anyone know where I might find something like that, or could have one made? Goal is to be as flat to the surface of the dash as possible so J can stick my Hula girl on it.
Many thanks!!
Ford Bronco Flat/flush center dash mount? IMG_7818
Dan-O
Dan
Fountain Hills, AZ
Unless I’m misunderstanding what you’re looking for……If the mounting hole will only be used to mount your “ Hula Girl”, couldn’t you just drill hole in bottom of hula girl and put in threaded stud?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Gladly make one out of ABS for a fellow Bronco owner. But can’t until end of the week.
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Many thanks!!
I turned some aluminum to make a flat base for my Hula Shark. But, a fender washer with a 1/4-20 button head screw would do exactly the same thing.
Ford Bronco Flat/flush center dash mount? 20260531_144012
Nc211
Nc211
Washington DC
Wow!! Really? I will gladly pay you for the time and materials (and shipping of course)! No rush no hurry at all. I’ll send you a PM shortly with details! Basically just looking for a small flat surface that I can place items like that on via some Velcro without having to mess with the dashboard surface itself. That would be awesome!!!
Nc211
Nc211
Washington DC
Yep, that’s basically it minus the rest of the setup, just the hula base to screw into the mount! Gotta have some fun in life!!
Squatch
It's just 1/4-20. There are plenty of camera and camera accessory pieces that would work, but a screw and fender washer (like @MFP2241 said) would likely be the cheapest option.
Nc211
Nc211
Washington DC
chopperbobby
bob
northern ky
2025 bronco
I purchased a part That added 3 places to screw in stuff. I purchased the Bronco buddy ref above. I did have to cut down the stud it stuck up too far in the new dash piece. Not sure if it will fit flush with oem one but easy enough to cut with Dremmel.
Ford Bronco Flat/flush center dash mount? IMG_4654
