Best Dash Rail Mount?
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Tackform for the win. Wish I had done this on my jeep. Went with bulletpoint on the jeep and the way its set up, you must remove the base plate to modify or add anything later.
Tackform on the bronco, baseplate stays and its extremely simple to add or modify anything without removing the entire thing.
SNOWOLF
Brandie
Maine
2023 Bronco
I did some searching, but could not find any consensus. I would like to stick with a no-drill solution.
The Ram Mount seems to be somewhat flimsy given its length and lack of support over the majority of its run.
The BAM Rail is nice, but really long and I think that you have to drill?
I am leaning towards the Tackform Fast Track; does anyone have any feedback on it?
I just received my Tackform rail system and wow it's really made nice.....more than I ever thought.
It also has the ability to use the rail or screw down accessories. Much nicer than 67 designs or Bulletpoint.
HowieLong
WNY
I had a RAM rail and removed it because it wasn't rigid enough for my purposes. I had a couple of Bulletpoint arms with phone mounts attached on each side and it would flex too much. I have the Mabett USB ports on the dash and want a rail that will work with them without modification and no drilling so I ordered the Goat Fab full length rail. It looks like it will work, plus I like the basic look of it. I do have the Tackform dash clip and the quality is outstanding.
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
I wish someone made a rail that goes to the A-Pillars.
Ton of wasted space at the ends and a MUCH better location to mount stuff IMO
Somehting that attached to the grab handle bolts - but then went all the way across
I see the next post answered your question,But here is one for sale on FB......
Ford Bronco Best Dash Rail Mount? 1704771617086
C6ZZGT
Seattle
Also we just got a RAM rail,no idea how well it will work on the trail but so far so good on the street.
thompsdw
Dean
Eden, UT
I have the rail from Mabett since it was first released and it has been fine . I painted the end caps and center piece A51 to match the Bronco. It uses standard camera mounts.
https://www.amazon.com/Mabett-Console-Multi-Function-Bracket-Aluminum/dp/B0C49FYHKW/ref=sr_1_27?crid=3CWOR7VWT0BUI&keywords=bronco+dash+rail&qid=1704739481&sprefix=bronco+dash+rail,aps,344&sr=8-27
I had Vector on my wrangler and the quality was very good. Does it use the Bronco center attachment point or keep it free? That might be the “key” for me as I would like to use the Mabett center power adapter.
JDoc92
Tim
Northern Illinois
2017 Honda Ridgeline
Another vote for Tackform. Nick and his crew will take care of you. I sold my Archetype Racing one. Really appreciate the compact size.
Ford Bronco Best Dash Rail Mount? IMG_2427
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
A lot of good information. Many thanks guys!
Bruno
Bruno
Sierras
HoosierSquatch
Ryan
Indiana
2023 Bronco
I know you said you'd like no drill/screw, but the Bulletpoint RubiGrid system is awesome. The base does screw to the dash, but in the unlikely event that I ever want to remove it, I'll just get some of those rubber inserts for the dash to cover up the holes.
Started with the accessory ball, arm, and phone holder knowing I’ll be able to add the rubigrid if I want to expand. Works pretty well solo.
Ford Bronco Best Dash Rail Mount? IMG_8086
Rydfree
Benny
Alabama
The Mabett rail uses the factory center mount.
Ford Bronco Best Dash Rail Mount? Dash rail
Frankie945
Frank
Louisville KY
Q50
Like others mentioned tackform is pretty nice. I totally dig it, just got it to hold a iPad and when the iPad isn’t in I place my phone in it.
Ford Bronco Best Dash Rail Mount? IMG_2181
