Fix for jingly JTOPS zippers?
GroovyGeek
Boyan
'23 Bronco BD
Installed a JTOPS sunshade over the weekend. Quality product through and through, once you see it you understand why it is 3x-5x more expensive that most bungee based solutions.
However, there is an extremely annoying quirk - the zipper pulls in the front hang down and jingle as the top flutters in the wind. I tried to mitigate by shoving the zipper pull in the little pocket at the end of the zipper and jamming it with the slider. However that works for all of 15 minutes before the vibration moves the slider enough to allow the zipper pull to fall out.
Are there known solutions to this issue, other than cutting the metal pulls and replacing them with 1mm black paracord or rubberized zipper pulls?
Enginerd
Jani
San Diego, CA
Audi S5 Sportback
I did exactly what you suggested with the paracord.
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350,25 2.7 BADLANDS SAS
I folded the zipper pull BACK into the webbing after I closed the opening. Mine always stayed tucked in.
GroovyGeek
Boyan
'23 Bronco BD
First thing I tried . Does not last even 5 mins.
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
I actually had pics of the zipper pull being tucked in the webbing and not the zipper end opening only because this has been discussed before, but alas..I can not find them.
GroovyGeek
Boyan
'23 Bronco BD
Since the built-in search is pathetic I googled it, found these threads
From 2022:
https://www.bronco6g.com/forum/threads/jtops-4-door-hardtop-mesh-bimini-review.51503/
@JTopsUSA responded to a message in this thread without ever addressing the floppy zipper handles.
Identical complaint here from 2024, with same proposed solution - cut and replace with fabric
https://www.bronco6g.com/forum/threads/jtop-bimini-shade-installed.46320/page-4
Another poster said "Got the heat gun out and applied electrical heat shrink tubing to the zipper pulls. Doesn't completely solve the issue but helps A LOT. "
Yet another solution "I just cut them off and I have a paperclip in my center console. There's no need to have something flopping all over the place up there "
@JTopsUSA responded to this thread with "Simple solution is to tuck the zipper heads. Works every time." Judging from my and others experience, this is most definitely not the case, unless there is some secret handshake to tucking.
Then there is a thread on FB with another solution I was considering - tuck the handle into the zipper opening
Like several posters have said, I can't believe that this was not caught and addressed during testing. To make matters worse it has been allowed to persist for years.
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
Unless JTops has changed designs since my top was purchased, I haven't had a zipper dangle after tucking it in the webbing. (Pic for example)
🤷‍♂️ crazy..
Ford Bronco Fix for jingly JTOPS zippers? 20260717_064709
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
I used the electrical shrink tubing method, applied heat with a heat gun (hair drier will also works), and it has worked well for me for a couple of years now.
Mjasi3
Chicago
Yes. Heatshrink.
GroovyGeek
Boyan
'23 Bronco BD
🤷‍♂️ crazy..
This looks like a canvas top, not a mesh top. The zipper pulls on mine are SUBSTANTIALLY larger.
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
ServoFides35
Raleigh
2024 Bronco Raptor and Wildtrak
Try taking some heat shrink tubing and covering the flappy part of the zipper. Heat it. Shrink it. See if that helps. May still flap but the jingle should be gone. Don’t melt the top.
23OBX2.7
AB Canada
2023 Bronco
Front top should not be fluttering. I adjusted mine after three weeks undid all the Velcro, lossened C brace, and pulled the back super tight while standing on bumper. Removed 98% of front slop but I'm now at limites with top starting to cover antenna and C brace element maxed out.
I may have to oval the c brace element holes and take top to my tailor if it stretches out more which I expect it will
