Fire extinguisher recommendations? Rear mounted options?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I’m not trolling here but I’ve never understood the need to add a fire extinguisher. I’ve been driving for over 25 years. Never had the need for one. Is it a bling thing? I mean really what are the chances that you will need one? If my bronco catches fire I’m gonna get out, let it burn and get a new one courtesy of my comprehensive insurance. I used to have one in my cobra but that was just for show purposes.
Legitimate question. What if someone is pinned with a seatbelt and you need time to cut it off before it gets to them? So a good knife or seatbelt cutter, glass breaker, etc, you hope you don't need them.
My thing is most people have no idea how to put a fire out or suppress a fire even if they did have them (those little stick ones, if you haven't practiced you will probably fail when you need it especially). Also, as Snacktime points out, having the wrong type isn't helpful either. Also, they don't last forever and need to be replaced every few years.
Anyhow, some adventure parks require it. In light Snacktime's trail partner hitting their head, mine just rolls around in the floor behind my seat. Not the best either way.
GroovyGeek
Boyan
'23 Bronco BD
People on this forum have a tendency to overpay grossly for LEDs and fire extinguishers. Both are a commodity, as long as you avoid no name Chinese stuff on Amazon you will be fine. The more important question is the carrier. After buying and returning a number of cheap poorly designed crap I got one from Warn.
GroovyGeek
Boyan
'23 Bronco BD
Some groups require it. I agree, it serves no useful purpose. Not big enough to put out a real engine fire. The chances of needing one are probably less than 1:10,000
stewart.chrisr
Warrenton, VA
2023 Wildtrak 4 Door
13 years as a fireman here. Maybe it's just odd luck for me, but I've put out at least 3-4 vehicle fires (never my own vehicle) using a 2.5lb extinguisher. None of them were when I was on duty and responding in a fire truck. A small extinguisher will absolutely work at the inception of a fire. It isn't going to work if you have a catastrophic incident where the fuel tank was ruptured and lights, or if you parked in tall grass and walked away, but they can and will work.
You also have to think not just of yourself, but of the environment you are in. Sure, your Bronco might have insurance. The same can't be said for the thousands of acres that might burn if your initially small fire turns into a forest fire because of an incident on the trails. My off-road club requires it, and I firmly believe it is a reasonable requirement.
I just got my Bronco, so I'll be perusing the options and deciding how to mount mine.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Only have one because some major offroad events require it, might move to one of those pointless Magic Disney wands if they accept them at events.
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 1705111550048
Area51BS
Area51BS
Ron
Badlands non SAS 4dr 2.3
Low chance. But what if you could get out, but a loved one couldn’t and it started to burn?
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
So I guess every vehicle should have a fire extinguisher on board? Just sayin’. To me unless it’s required because of some group ride rule, there’s no reason to have one on board.
5GENIDN
Joe
Idaho
Well I live out west where a catalytic converter can start grass fires.... Or drag chains sparking can start a fire..... Those fires get out of hand really quick. For me, while I acknowledge there is a slim chance of vehicle fires - there is a chance and that is not the winning lottery ticket I want.... I have seen problems on the road that other people are experiencing and if I can protect the hundreds of thousands of acres of grass lands and forest by just getting to a small fire quickly and easily.... I am going to be happy I was prepared.... Better yet if I do not ever need it.
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
Not all public gathering places have defibrillators available either. But I bet you'd want one ready to go if you happen to drop from a heart attack while you're out and about. I know I would...
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I had a couple of rechargeable Kidde extinguishers mounted on the rear tray in my Wrangler and used them a couple of times to put out a car fire before it raged out of control.
I plan to reinstall them on the rear bars in the Bronco. Would rather have them and not need them versus the opposite.
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 20210213_184431
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 20210213_184445
Area51BS
Area51BS
Ron
Never said every vehicle. Not suggesting mandatory either. Just a good idea to have one. Kind of like the idea of each town having a fire department. Might have helped a person or two.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I think the chances of having a fire in a town is quite a bit higher than a fire in your car. Fire extinguishers in a Bronco are needless based on the odds. Chances of a fire are negligible. It’s just showmanship.
Area51BS
Area51BS
Ron
Mine isn’t visible.
rbalazs
Ryan
Snohomish Wa
2024 f350 HO Tremor, 2023 Bronco Badlands Sasquatch
Of course, in my normal fashion, I fabbed up my own bracket. I also used a drill and some thousand grit sandpaper to polish up the sides of the Alan bolts, securing it to the roll bar and then use the drill and my wife’s red fingernail polish to put a racing stripe on the bolts.😂
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_9416
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_9417
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_9421
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_9422
