Fire Extinguisher Mounted Pics - Post Em!
Ground_zero298
Scs michigan
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Lmao. Just put mine in today and the first aid kit. Found a nice quick release on Amazon for it. Seems a little under priced for the quality of it. 2 pilot holes and a pair of self tappers, done.
https://www.amazon.com/gp/aw/d/B07PCM6TM2?psc=1&ref=ppx_pop_mob_b_asin_title
Now I just have to paint my chainsaw red and figure out where to mount that.
Hmm I just ordered the same one under a different brand name. That location doesn't seem too bad if you use the quick release. Except I still have a seatbelt there...
roofone2
Boston
A4
Bschurr
NY
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 5F842A44-4FA2-47BF-99AA-46AAB2B30FE0
Element fire extinguisher secured by 2 magnetic mounts on the rollbar and @604Bronco a pair of Quick Fists screwed to the rollbar woth M8 bolts to secure a small shovel…
Mdemieville
mark
2011 Lincoln MKZ hybrid
+ 1 for the mOaR dOoR, eh @Tricky Dick? :sneaky:
I’m curious if anyones bolted anything to the rear roll bar, where those two exposed holes are. Seems like a logical spot.
I plan on mounting fire extinguishers on both sides in those mounting holes. Just gotta get the extinguishers.
TheShark
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 65C34107-29DB-4B1A-AA27-BBE64DF00655_1_105_c
Pacific Ryder
Marin County, CA
2019 Ford Raptor/1993 Jeep YJ
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Inrustwetrust_
Alex
Peoples Republic of Massachusetts
2021 Bronco 2dr
Built right molle panel. Not fully mounted yet but I tested the Velcro extinguisher mount
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 8E2EE5F8-296A-4CD2-B0BD-5EB98CF07B1A
BroncoKong Jr.
Andrew
The seat rail mount just affixes via allen screws to your exiting seat rail. The extinguisher is held in with dual clips. You can see it better here:
https://elementfire.com/products/seat-rail-mount
I've been having some trouble with that mount. The seat doesn't slide over it like it should. If that's not an option, then it's kinda worthless to me. For now the Element is in the glove box.
Maybe I'm doing it wrong. Do you have a pic of how your bracket is mounted?
