Fender removal for Bronco Raptor - instructions / guide?
rivasrubicon
Patric
San Antonio
Genesis G70, 2018 Corolla
I have a question, does the removal of the Braptors fenders appear in any manual or is there a guide to look at?
Moribach
Canada
23 Braptor
I'm interested in this as well. From a PPF perspective, do those Fender Flares come off on a Raptor and what instructions exist on it.
JohnGalt
Tahoe, CA
2023 Defender 110
They are “removable”, but not easily like Sasquatch flares. If you want to install ppf under them it may be worth the effort, my ppf installer has done it on two. But he didn’t like it and needed plenty of replacement clips.
even if you could take them off easily, it’s ugly as sin under there
Ducati1098
501-08 Exterior Trim and Ornamentation
2022 - 2023 Bronco
Removal and Installation
Procedure revision date: 07/5/2022
Front Fender Moulding - Raptor
Removal
NOTE:
Removal steps in this procedure may contain installation details.
NOTE: LH side shown, RH side similar.
  1. With the vehicle in NEUTRAL, position it on a hoist.
    Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
  1. Remove the LH side front wheel and tire.
    Refer to: Wheels and Tires (204-04A Wheels and Tires, Diagnosis and Testing).
  1. Remove the fender splash shield.
    Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
  1. Remove the front fender moulding.
    1. Press the lugs and release the pushpins from fender.
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? Screenshot_20230112_215542_Chrom
2022 - 2023 Bronco
Rear Quarter Panel Moulding - Raptor
Removal
NOTE:
  1. Remove the LH side wheel and tire.
    Refer to: Wheel and Tire (204-04A Wheels and Tires, Disassembly and Assembly).
  1. Remove the bolt and retainers and rear shield wheel splash.
    Torque: 15 lb.in (1.7 Nm)
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? video
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? Hel
  1. Remove the rear fender splash shield.
    Refer to: Rear Fender Splash Shield - Raptor(501-08 Exterior Trim and Ornamentation, Removal and Installation).
  1. Release the tabs and remove the stone cuff.
  1. Loosen the wheel molding bracket.
    1. Remove the screws.
      Torque: 97 lb.in (11 Nm)
    1. Press the lugs and release the pusch pin retainers from pannel body.
    1. Remove the retainers.
  1. Remove the rear quarter panel moulding.
    1. Press the lugs and release pushpins from the quarter panel and remove the rear quarter panel moulding.
rivasrubicon
rivasrubicon
Patric
San Antonio
2022 - 2023 Bronco
Removal
NOTE:
2022 - 2023 Bronco
Removal
NOTE:
Thank you so much!!!
Silverstrandtek
Jeremy
San Diego, CA
Bronco Code Orange
You’ll realize when you’re taking the flares off that there’s bolts and then there’s a bunch of single use plastic clips. You’ll end up destroying a bunch of the clips and Ford doesn’t sell the clips separately of the flares. Here’s a link to the replacement clips that fit close enough.
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1648
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1649
swamp2
Thanks! Great tip.
Aren't there multiple types of plastic fasteners (clips) used for the attachment of the fenders associated plastic parts?
Perhaps none of them tend to break doing this job except one type?
I'd bet the Ford OEM part(s) is (are) used broadly across many vehicles and is available from Ford somehow.
FLSTFI Dave
East TN
2018 Grand Sport, Carbon 65, 2017 F-150
I guess I just do not under stand the terms used to describe the removal. Is the splash shield the inner flare liner? I know that has to be removed before you can get to the Flare push pins.
vrtical
Doug AI
GSMNP, TN
Fords
Just wait until you rip one off then it's a non issue
FLSTFI Dave
East TN
Didn't rip it off. smacked hit hard when I slid sideways into a wall. Several busted clips. So I need to know how to get it off in proper order to reinstall the broken clips.
