Fender flare repair
Riverwolf
Eastwood, North Carolina
2022 Ford Bronco
Good morning, I have a 2022 Bronco Base w/Sasquatch package. Do to a rogue tree I managed to separate the right rear fender flare into two pieces. Is it possible to re-attach the top part to the bottom?
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Depending on how clean of a separation, it should be easily resolved with some JB Weld. If you never used it before, practice on a some scrap plastics to get a feel for the process. Once it sets, it is permanent.
Squatch
Just take them all off? :wink:
I get that not everyone likes that. Aside from JB Weld, you may want to(I haven't checked if it's possible, but wear a respirator) make some soldering iron plastic "stiches" on the backside, for esthetics, as well. If none of that made sense, I bet there are plenty out there for cheap like @MNBigfoot already said. 😁
CalvinT
Calvin
Phoenix, AZ
3M sells adhesives designed for gluing the plastics used in automobiles. But they're expensive, $55 on Amazon, and require a dispensing gun. If you're careful you can get by without the gun.
contented
Karl
Central Fl
BMW M2 Competition
JB Weld
