popo_patty
Caleb
Sacramento
I know, I know, they are the same right? So why the comparison?
Well because it was confusing to me at first so I wanted to make a thread to hopefully alleviate any confusion that others may have.
As far as tech specs these axles (I have the M210 shown here), are very similar. In fact, they are essentially the same. Or are they?
Spline count: same.
Metal: same.
Angle of operation: same.
Strength: same.
Where these bad boyz begin to differ is the attention to detail and price point.
The Ford Performance (FP) axles have a coating on them vs the OEM are bare. In the long run this should mean less prone to that ugly corrosion we see on all our stock axles.
The packaging on the FP is also way better with sealed bags and wadding. The OEM’s were just wrapped in paper for me.
Now the coating alone for me is a deal maker. Give me a coating any day. But it gets even better…
Ordering the OEM axles from Ford cost me over $700 out the door.
Ordering the FP was $460… that’s a huge cost savings for a better product with safer packaging for storage.
Note that the part numbers are different as well.
If anyone here has any info on why the FP is so much cheaper I’d love to be educated. Also, does anyone here have factual info on wether or now the metal is different? Thanks!
And then as an added bonus, check out my spare inner. I noticed the sealed packaging was rotting (after a year in a dry container) and it was browning. I pulled out the inner and saw rust coating it and the inner was frozen up. I managed to break it free but the damage has been done. It was internally corroding.
Ford Bronco Factory OEM axles vs. Ford Performance axles F682B6C2-BE27-48C0-9903-F8765E70322D
Ford Bronco Factory OEM axles vs. Ford Performance axles A3E3A3C1-BA23-41F0-9AFE-21C0A266E2E6
Ford Bronco Factory OEM axles vs. Ford Performance axles F149124F-271E-4452-8272-93FABB0DC757
Ford Bronco Factory OEM axles vs. Ford Performance axles 0E2E2BD7-0F56-43B3-8F39-3BA4AC604F35
Ford Bronco Factory OEM axles vs. Ford Performance axles 4F1AB6A1-59A7-4D10-88D0-681BAE2898D3
Ford Bronco Factory OEM axles vs. Ford Performance axles A862789C-2CBE-4D19-BE3F-25A31C0ED205
Ford Bronco Factory OEM axles vs. Ford Performance axles 07B49BC6-15A4-4A8B-BCD9-82C4C511EAAC
Ford Bronco Factory OEM axles vs. Ford Performance axles F704BFE8-DB5B-4DB2-BA43-AA00BB9D9F21
Ford Bronco Factory OEM axles vs. Ford Performance axles 61A23666-8F59-44D1-B590-FB8D064D8FBF
Bronco_joe
joe
Niagara Falls. NY
I couldn't find this answer also. I purchased mine even cheaper when they offer discount codes.
Heckler
Larry
San Mateo
2023 Bronco
Was your spare inner ever used?
Mudlight
Brent
Badsquatch
Do they come with new axle nuts?
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
According to another forum found here the oem units retain the original warranty, but the FRP units do not. I guess that could explain why they are less expensive, but I can see some dealers trying to squeeze a voided warranty due to "rough driving" or some sort of nonsense.
Finbox
FL
KLR650
They could be different under the boots that’s the weak point
explorer4x4
Anthony
Delaware
Base 2DR Eruption green
I bought the FP axles for a M210 upgrade from the M190. The FP drivers axle was too long. The stub that goes into the unit was almost 1/2 inch longer than the Ford unit. Not sure if it would cause issues or not as the splines still inserted. The outer seal protector plate wouldn’t do its job and part of the shaft would rust. But the seal should still seal. I bought a stock axle anyway to install.
Ford Bronco Factory OEM axles vs. Ford Performance axles IMG_3384
explorer4x4
Anthony
Delaware
Also if you think your FP axle stub looks different. It’s bc I turned the lip off mine down with my lathe. I thought that’s what was preventing full insertion. Before I had the Ford axle of course. I tried resolving that issue with FP including another larger issue with my axle upgrade. I’ve heard nothing back so far. All I’m saying is compare the lengths of the drivers stub
popo_patty
popo_patty
Caleb
Sacramento
Yea the M210 axles are different then the M190. Not sure if FP makes a version for the 190 or not.
