Factory-installed slide-out tailgate removal
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Has anyone done it?
It appears I need to order the standard floor panel, (4) tie-downs and rear plastic trim.
I'm unclear if the standard tie-down bolts (small and large washer?) are the same used for the slide-out tailgate mounting.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Why? I love mine.
That said, you will need the 4 floor d-rings with bolts, 4 d-ring covers rear trim piece, floor and mat.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Sounds like you pretty much named it all. Too bad you're not local or I would love to trade my floor for one of these.
Watch an installation video and you will be able to see what exactly they removed.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
Why? I love mine.
I simply never use it. It adds loading height, slightly reduces cargo floor area, and Ford still refuses to offer a mat for it.
It's dead weight because I never use it. I wish it had been an option, rather than standard equipment......there are other options unavailable on the Everglades that I'd rather have more.
Johnny Mo
Westchester County, NY
teachu2shoot.com
Why? I love mine.
And also the door threshold replacement this might help just follow in reverse.
Ford Bronco Factory-installed slide-out tailgate removal PXL_20240702_123725695
Ford Bronco Factory-installed slide-out tailgate removal PXL_20240702_123712488
Ford Bronco Factory-installed slide-out tailgate removal PXL_20240702_123734420
Ford Bronco Factory-installed slide-out tailgate removal PXL_20240702_123743380
Callelk
Larry
Idaho
RagnarKon
Ford Bronco, Escape, Focus
Yeah, correct.
You will need the rear tie-down points, the trim pieces for the tie-town points, and the giant load floor piece. You can go either with the rubberized vinyl load floor that's standard on the Black Diamond/Badlands trim or the carpeted that standard on Big Bend/Outer Banks/etc.
And yes, the bolts are different, but they're just standard metric threads, so you can hardware store those that if you want.
Parts:
  • Tie towns:
    • (4) M2DZ-78550A74-A
    • (4) M2DZ-78313A68-AA
    • (2) W706027-S439
  • Load floor
    • Carpeted: M2DZ-7813046-D
    • Vinyl: M2DZ-7813046-B
You should probably double-check my part numbers with the help of your dealership parts counter. And of course, they can order it all for you.
It'll probably be just shy of $1000 to make the switch, with the bulk of the price being that load floor. May be a smart idea to find someone on the forum who wants the slide-out tailgate and do a simple parts swap.
userdude
Denton, TX
2023 2dr Badsquatch
Didn't somebody put an airline cargo mat w/tie downs down instead of the floor? Was that @KABQ?
Callelk
Larry
Idaho
Just sent the instructions to you via msg. Everything that shows being tossed into the trash is the parts you need to replace the SOTG.
Ninjak
Miami
Lol and I just bought a slide-out tailgate. I did not check before, but I see you have a Everglades. Standard on that model.
As others said, it may be best to find someone local to you who wants a slide-out, and just arrange to have the parts swapped.
huey
kevin
Ontario & Kentucky
dammm - if only you were closer we could swap out!
KABQ
Aaron
Albuquerque, NM
It wasn't me, but yeah someone put aircraft seat track back there. I can't find it with a quick search, but I'll look again. It's a freaking good idea!
KABQ
Aaron
Albuquerque, NM
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
Yeah, correct.
Parts:
  • Tie towns:
    • (2) W706027-S439
  • Load floor
Thank you !
