Factory Fog Light Switch
zuke
Stafford VA
Did you ever find a solution to this? I have fog lights on order and a Big Bend mid package with modular bumper and no connectors located by the tow hooks. Was hoping to install a factory switch to use for the fog lights. I'm wondering if there is somewhere else in the factory harness to tap in to do this. Can anyone help?
If your bronco didn't have fogs or sensors originally, you're going to have to go back to C203, Wich is a large harness connector inside the driver's fenderwell... Take the liner out of the driver's side, and look up on the frame horn that runs immediately under the fusebox/battery area... the connector is the large one in this photo;
Ford Bronco Factory Fog Light Switch Untitled
Ford Bronco Factory Fog Light Switch location
Ford Bronco Factory Fog Light Switch wiring
The two wire connector you see is the one I added for mine, you need to splice the wires going to pin 48 and 43 of C203, 48 is a yellow/orange wire to the + right light, and 43 is brown, to the left light. you just need to ground the other wires from the fog lights.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
@zuke - your photos aren’t loading.
This is my plan.
Valhalla
Valhalla
Chattanooga Tn
Only on the first page here, however, why not wire one upfitter to relays and power the whole thing off one? unless you want to only light some of them.
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Thanks Zuke. Can't see your photos, but it sounds like this worked for you. Did you also need to activate everything with Forscan after making the connections? Also, by using these wires, do you know which fuses the fog lights operate off of (just curious as to whether they need to be installed)? Would appreciate another attempt at up loading photos, and thanks again.
zuke
Stafford VA
Put the pictures in a different format, can you see them now?
There are no fuses, Power comes directly from the BdyCM (Body Control Module) Which is coincidentally, what you have to change in Forscan as well, if you go to BdyCM in Forscan, There are several options for it, I Used "Fog Only" for it to work the way one would normally expect..
Bill K
Allen, TX
Much better on the picture front! Thanks again - you're a wizard. I have all of the Forscan stuff, just need to dig into it. Getting ready for many mods - lighting as well as rigging for flat towing. I have a buddy with a lift that he's generously offered to let me use. I told him I would need more than a day, this might be morphing into about a week...
zuke
Stafford VA
A lift makes it so much easier, you can pull the wheel and liner easily, and work comfortably that way! I can't imagine doing that wiring on jackstands, Your neck would be sore after 30 minutes :)
Hatman
Argyle, Texas
Badlands Sasquatch 2.7L
Ford Bronco Factory Fog Light Switch 39ADEA7B-3F29-4BF3-A54E-B26F6E97A34F
Ford Bronco Factory Fog Light Switch 27AC7765-00A7-432C-A9D1-4DA903404545
Ford Bronco Factory Fog Light Switch E609993F-8B77-4B38-B481-B95BE0C634E8
somewhere near the beginning of this thread, someone suggested speaker connectors from Amazon might work. I ordered them dirt cheap and considered filling them with caulk for weatherproofing. Instead, I cut the weatherproof plugs that were in the bumper (protecting the wire harness female plugs) and took the gaskets out, made a hole in the center and slid the wires through. They are perfectly sealed and the speaker connectors are an exact fit. Made all of my FORScan changes and my Rigid lights are working great. I had them on an upfitter switch but wanted to add the cornering function. The Amazon connectors are a great way to go especially if your lights are bare wire with no connectors.
4 Pack Speaker Harness Replacement for Ford Lincoln Chevy GMC Mercury Mazda Models Front Rear Door Speaker Wiring Harness Adapter 72-5600 - Door Speaker Replacement https://a.co/d/8GxJZsk
Tabman10
MI, USA
2022 Bronco
Hi All,
Sorry if this has already been covered, but does anyone happen to know what the maximum amount of current that the OEM Fog Light circuit can drive?
I am looking to use this circuit to drive Diode Dynamics SSC2 Pro fog lights (rated at 2A each), so if anyone can confirm they have successfully done this, it would be a good as a value…
Thank you.
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Hi All,
Thank you.
1.21 jigawatts. Sorry, I couldn't resist.
zuke
Stafford VA
Hi All,
Thank you.
I'm running two 20 watt Sylania Lights on mine.. The Factory Fogs are 20 watt as well, so it should be able to handle 6 Amps total, but you have to use both circuits for that.. I did run them both off one circuit for about a week, and didn't see any ill effects during that...
CarbonBronco
Tony
Socal
99 Toyota $runner
So since my Bajas have a harness can I technically wire just to either the brown wire or the yellow/ orange wire?
zuke
Stafford VA
You Technically can, I did exactly that for a bit, But you'll have to turn on just one in Forscan, or you'll probably get errors for the one that doesn't have anything connected to it. Also you're putting twice the load that the factory is putting on that wire if you do.
So, Can you? Yes, But I wouldn't reccomend it.
ssypien
Stan
IL
2022 Bronco Wildtrak
Thanks to all that have contributed to this thread, added my dogs yesterday and everything works great!
Ford Bronco Factory Fog Light Switch IMG_4713
Ford Bronco Factory Fog Light Switch IMG_4711
Ford Bronco Factory Fog Light Switch IMG_4709
Ford Bronco Factory Fog Light Switch IMG_4707
Ford Bronco Factory Fog Light Switch IMG_4708
