Electrical Systems Failure, Caused By MIC 2.0 Leak
fdac
Frank
Islip NY
2006 Hyundai Tiburon, 2018 Harley Davidson FXFBS
21 minutes ago
I just accepted delivery of a 2021 Ford Bronco, with the Black Diamond Trim. I have a serious problem. The MIC 2.0 removable top, that I waited 4months and 6 days for FORD to replace leaked. The leak caused electrical system failure and potentially damaged multiple electrical systems and components. I am attaching A vehicle System Health report I pulled this morning. I did not clear the DTC codes as of yet. I will be sending a copy of this report, to the National Highway Safety Administration along with a formal complaint. I am also going to post my results on this forum.
Full Vehicle System AI Inspection Report
The Report is created by TOPDON
Repair Shop
SN:988989909619
Test Time:02/19/2022 10:44
Vehicle Information
Make:USAFORD
Model:Bronco
Year:2021
VIN:1FMDE5AH0MLA68643
Odometer:0km
Vehicle Software Version:V48.75
Inspection Result
ABS (Anti-Lock Braking System) 10 problems exist
1.P05D3:86-28 Driver Mode Selection Switch #A
Range/Performance Fault
2.C1034:44-68 Parking Brake
3.C2006:74-28 Left Actuator
4.U0131:00-68 Lost Communication With Power
Steering Control Module A
5.U0138:00-28 Missing Communication With All
Terrain Control Module
6.U0151:00-68 Missing Communication With
Restraints Control Module
7.U023A:00-28 Missing Communication With Image
Processing Module #A
8.U0265:00-28 Missing Communication With Image
Processing Sensor #A
9.U0401:83-2C Data Received From ECM(Engine
Control Module)/PCM (Powertrain Control Module) A
Is Invalid
10.U3003:16-68 Battery Voltage
APIM (Accessory Protocol Interface Module) 1 problems exist
1.U0212:00-08 Missing Communication With SteeringColumn Control Module
ATCM (All Terrain Control Module) 3 problems exist
1.U011D:00-08 Missing Communication With AWD (All
Wheel Drive) Control Module
2.U0140:00-08 Missing Communication With
BCM(Body Control Module)
3.U01B7:00-08 Missing Communication With Switch
Input Module A
AWD#1 (All Wheel Drive Module) 5 problems exist
1.U0138:00-28 Missing Communication With All
2.U0151:00-28 Missing Communication With
3.U0212:00-28 Missing Communication With Steering
4.U0415:00-28 Invalid Data Received From ABS (Anti-
Lock Brake System) Control Module A
5.U1014:00-68 Invalid Internal Control Module
Monitoring Data Received From Restraints Control
Module
HVAC (Heating Ventilation Air Conditioning) 1 problems exist
1.U0452:82-08 Received Invalid Data From Restraints
Control Module
IPC (Instrument Panel Control Module) 3 problems exist
1.U0151:00-08 Missing Communication With
2.U0212:00-08 Missing Communication With Steering
3.U023A:00-08 Missing Communication With Image
IPM-A (Image Processing Module A) 4 problems exist
1.U0140:00-68 Missing Communication With
2.U2018:51-28 Control Module Software #3
3.U3000:49-28 Control Module
4.U3003:16-28 Battery Voltage
OCSM (Occupant Classification System Module) 1 problems exist1.U0100:00-28 Missing Communication With
ECM(Engine Control Module)/PCM (Powertrain
Control Module) A
PCM (Powertrain Control Module) 3 problems exist
1.U0151:00-28 Missing Communication With
2.U0212:00-28 Missing Communication With Steering
3.U0415:00-28 Invalid Data Received From ABS (Anti-
PSCM (Power Steering Control Module) 1 problems exist
1.U0415:00-28 Invalid Data Received From ABS (Anti-
RCM (Restraint Control Module) 5 problems exist
1.B00A0:68-08 Occupant Classification System
2.U0100:00-08 Missing Communication With
Control Module) A
3.U0140:00-08 Missing Communication With
4.U0154:00-08 Lost Communication With Restraints
Occupant Classification System Module A
5.U0253:00-08 Missing Communication With
SCCM (Steering Column Control Module) 5 problems exist
1.B1131:08-28 Wiper Motor Module
2.U0140:00-28 Missing Communication With
3.U0146:00-28 Lost Communication With Serial Data
Gateway A
4.U0155:00-28 Lost Communication With Instrument
Panel Cluster (IPC) Control Module
5.U023A:00-28 Missing Communication With Image
The following systems are OK:
1.ACM (Audio Control Module)
2.DDM (Driver Front Door Module)
3.GWM (Gateway Module A)4.PDM (Passenger Front Door Module)
5.RTM (Radio Transceiver Module)
6.TCU1 (Telematic Control Unit Module)
7.TRM (Trailer Module)
Garden Hose Car Wash
Leaking In The Rain
fdac
fdac
Frank
Islip NY
Thank you ManyG20 for your support
phocion
Portland, OR
2010 Mustang
Ford Bronco Electrical Systems Failure, Caused By MIC 2.0 Leak 65ukkl
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
21 minutes ago
Repair Shop
SN:988989909619
Vehicle Information
Make:USAFORD
Model:Bronco
Year:2021
Odometer:0km
Inspection Result
Is Invalid
Input Module A
Module
Control Module
Control Module) A
Control Module) A
Gateway A
Now I am confused...... I thought these things were supposed to be able to endure getting wet inside, (hence the drains in the floors, the marine grade vinyl seats (marketed as washout interior), etc.
Even a leaky top should introduce less water than having the top off in an unexpected rainstorm.
Bottom line is that I feel doubly bad for Frank because of these failures. Sure hope they can be resolved permanently and quickly by your dealer.
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
These hard tops are trash, just stating this fact with all the evidence ends up causing extreme butt hurt in some members for some reason though.
Some are trash, sure. But are you taking the 10’s of thousands of silent owners into consideration? Only the affected are vocal, making a blanket statement like that is silly. Soft top, 2.7, windshield wipers must be trash, too?
Lil Red Broncette
Explorer
Not trying to be an ass here, but this sounds like an end of the story and I am lost as to what led to this point.
So do I have this right, there was a leak that occurred since you took delivery (or sometime while in ford's hands before delivery), vehicle appeared fine at delivery and you left but then noticed problems (or leak occurred after causing problems) that are either major making it undriveable or drivable but with many things not working?
That would really suck.
Or, does the vehicle seem fine, but you have some suspicion because of evidence of a leak so did a diagnostic and uncovered that looks like massive amounts of issues?
grayshadow
Charles
Humble, Texas
Many times strange electrical issues are due to a bad ground. Has the ground near the fuse block been checked since it has been reported that many have had issues.
Not implying your diagnosis is incorrect just adding a suggestion.
fdac
fdac
Frank
Islip NY
The switch bank in the center of the dash board filled with water from the roof leak. I went to get a rag and the water had disapeared into the dashboard. The next time I started the vehical the electrical system went crazy and displayed 12 error messages. When I pulled the health report All electrical system failures were no logger displayed on the instrument cluster and all systems seem to be operating as normal.
Ares
Fox
Atlanta
I think its protected from some water intrusion, a sprinkling, it is not IP67 waterproof. "hosing down" should be done gently, to only the floor area. some sprinkling on the vinyl seats will be OK, but getting water on the IP could easily go very wrong..
fdac
fdac
Frank
Islip NY
I washed the truck and when I opened the door I noticed water dripping from above the aux switches into the dash switch bank. The dash switch bank only has three switches on the Black Diamond trim. It was filled to the top with water, when I returned with a rag the water was gone. There were major electrical system failures immediately after that. The roof was on when I washed the vehicle.
MadMan4BamaNATL
Ray
Atlanta
Do you think it was a sealing problem or something else? You do know they’re going to accuse you of not properly reinstalling the roof panels, so I hope you have plenty of pictures and maybe video.
Messed up that this happened with the newer roof and hope it was some sort of fluke.
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
See, told you. The blanket statement being made is that there are “10’s of thousands” hard tops out there...not even close to that.
