Electrical Systems Failure, Caused By MIC 2.0 Leak
Deleted member 32220
Guest
There is a TSB for the header seal. Unsure if it could be the source of your leak but I know owners observed water leaking out of the airbag covers on the A-Pillars. Worth a look anyway.
Good luck. Sorry you're dealing with this
EDIT: Link to the TSB thread
Either way it’s a shit design with bolts going through it. The water will still find a way, and corkscrew right down those threads into your dashboard area somewhere.
Southern Girl
1974 Bronco/2024 Wildtrak
, windshield wipers must be trash, too?
Yes. Yes they are. I hate the windshield wipers and I live in Florida. The fast speed is like high intermittent. Thanks for bringing that up. I was hoping there is a way to get a better motor installed so I can actually see when it rains.
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Guy takes bronco through car wash with doors off and all systems go. Puddle of water disappears from dash and cooks the electrical system. 🤷‍♂️
North7
North Texas
SUV
Remember, Ford told us Bronco's were not designed for "extreme humidity".
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
21 minutes ago
I just accepted delivery of a 2021 Ford Bronco, with the Black Diamond Trim. I have a serious problem. The MIC 2.0 removable top, that I waited 4months and 6 days for FORD to replace leaked. The leak caused electrical system failure and potentially damaged multiple electrical systems and components. I am attaching A vehicle System Health report I pulled this morning. I did not clear the DTC codes as of yet. I will be sending a copy of this report, to the National Highway Safety Administration along with a formal complaint. I am also going to post my results on this forum.
Full Vehicle System AI Inspection Report
The Report is created by TOPDON
Repair Shop
SN:988989909619
Test Time:02/19/2022 10:44
Vehicle Information
Make:USAFORD
Model:Bronco
Year:2021
VIN:1FMDE5AH0MLA68643
Odometer:0km
Vehicle Software Version:V48.75
Inspection Result
ABS (Anti-Lock Braking System) 10 problems exist
1.P05D3:86-28 Driver Mode Selection Switch #A
Range/Performance Fault
2.C1034:44-68 Parking Brake
3.C2006:74-28 Left Actuator
4.U0131:00-68 Lost Communication With Power
Steering Control Module A
5.U0138:00-28 Missing Communication With All
Terrain Control Module
6.U0151:00-68 Missing Communication With
Restraints Control Module
7.U023A:00-28 Missing Communication With Image
Processing Module #A
8.U0265:00-28 Missing Communication With Image
Processing Sensor #A
9.U0401:83-2C Data Received From ECM(Engine
Control Module)/PCM (Powertrain Control Module) A
Is Invalid
10.U3003:16-68 Battery Voltage
APIM (Accessory Protocol Interface Module) 1 problems exist
1.U0212:00-08 Missing Communication With SteeringColumn Control Module
ATCM (All Terrain Control Module) 3 problems exist
1.U011D:00-08 Missing Communication With AWD (All
Wheel Drive) Control Module
2.U0140:00-08 Missing Communication With
BCM(Body Control Module)
3.U01B7:00-08 Missing Communication With Switch
Input Module A
AWD#1 (All Wheel Drive Module) 5 problems exist
1.U0138:00-28 Missing Communication With All
2.U0151:00-28 Missing Communication With
3.U0212:00-28 Missing Communication With Steering
4.U0415:00-28 Invalid Data Received From ABS (Anti-
Lock Brake System) Control Module A
5.U1014:00-68 Invalid Internal Control Module
Monitoring Data Received From Restraints Control
Module
HVAC (Heating Ventilation Air Conditioning) 1 problems exist
1.U0452:82-08 Received Invalid Data From Restraints
Control Module
IPC (Instrument Panel Control Module) 3 problems exist
1.U0151:00-08 Missing Communication With
2.U0212:00-08 Missing Communication With Steering
3.U023A:00-08 Missing Communication With Image
IPM-A (Image Processing Module A) 4 problems exist
1.U0140:00-68 Missing Communication With
2.U2018:51-28 Control Module Software #3
3.U3000:49-28 Control Module
4.U3003:16-28 Battery Voltage
OCSM (Occupant Classification System Module) 1 problems exist1.U0100:00-28 Missing Communication With
ECM(Engine Control Module)/PCM (Powertrain
Control Module) A
PCM (Powertrain Control Module) 3 problems exist
1.U0151:00-28 Missing Communication With
2.U0212:00-28 Missing Communication With Steering
3.U0415:00-28 Invalid Data Received From ABS (Anti-
PSCM (Power Steering Control Module) 1 problems exist
1.U0415:00-28 Invalid Data Received From ABS (Anti-
RCM (Restraint Control Module) 5 problems exist
1.B00A0:68-08 Occupant Classification System
2.U0100:00-08 Missing Communication With
Control Module) A
3.U0140:00-08 Missing Communication With
4.U0154:00-08 Lost Communication With Restraints
Occupant Classification System Module A
5.U0253:00-08 Missing Communication With
SCCM (Steering Column Control Module) 5 problems exist
1.B1131:08-28 Wiper Motor Module
2.U0140:00-28 Missing Communication With
3.U0146:00-28 Lost Communication With Serial Data
Gateway A
4.U0155:00-28 Lost Communication With Instrument
Panel Cluster (IPC) Control Module
5.U023A:00-28 Missing Communication With Image
The following systems are OK:
1.ACM (Audio Control Module)
2.DDM (Driver Front Door Module)
3.GWM (Gateway Module A)4.PDM (Passenger Front Door Module)
5.RTM (Radio Transceiver Module)
6.TCU1 (Telematic Control Unit Module)
7.TRM (Trailer Module)
@Ford Motor Company
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
These hard tops are trash, just stating this fact with all the evidence ends up causing extreme butt hurt in some members for some reason though.
So far my MIC 2.0 seems do be doing fine. The fit and finish are what I would expect and it doesn’t leak even when I use a power washer to clean it. Time will tell if it stays that way. I will add that almost 20 years go my 911 targa glass roof would leak whenever it got wet and that was a much more expensive car.
RedHotFuzz
2022 Bronco Black Diamond 4D
Out: Don’t wax your Bronco top.
In: Don’t wash your Bronco top.
WuNgUn
Ontario Canada
2 door Squatched
Many times strange electrical issues are due to a bad ground. Has the ground near the fuse block been checked since it has been reported that many have had issues.
Not implying your diagnosis is incorrect just adding a suggestion.
Seeing as there are so many modules that's aren't communicating at all, it might be something as simple as this. The Bronco would of had to be submerged underwater to see this kinda failure in so many areas.
Did this roof leak at the A-pillars like the other "ABS cover" leak Bronco's? The one they issued a TSB for?
WuNgUn
Ontario Canada
2 door Squatched
Mine seems good as well... I've noticed some slight intrusion when I get crazy with the power washer though. 🤷
Roger123
Roger
VA Beach, VA
The switch bank in the center of the dash board filled with water from the roof leak. I went to get a rag and the water had disapeared into the dashboard. The next time I started the vehical the electrical system went crazy and displayed 12 error messages. When I pulled the health report All electrical system failures were no logger displayed on the instrument cluster and all systems seem to be operating as normal.
So everything's fine now??
WuNgUn
Ontario Canada
2 door Squatched
The problem, as far as I can tell is that the water entered through the center seam. It flowed over the auxillary switch bank and filled the hero switches on the dash. It was gone by the time I returned with a rag. The six plastic latches that hold the roof on dont operate smoothly and I believe they are flexing the roof panels.
When you say flexing the panels... Perhaps the panels aren't laying flat where they're s'pose to be? Maybe something is overlapping where it shouldn't be? Pinched or overlapped seal?
Lil Red Broncette
Explorer
Damn, that is disturbing.
As an engineer who has some experience with automotive electronics, all the faults you saw are not necessarily caused by a widespread issue. So there is hope the injury to the systems is localized.
There are data communications buses that enable all this diagnostic stuff and is used to send data back and forth between different systems within the vehicle for control and diagnostic purposes. So, for example, the buss that communicated with the hero switches may have been impaired and it blocked communication with everything else on that buss causing both diagnostic and functional problems. That isn't to say water didn't get into a whole bunch of things, but it could have been just one fault from water interfering with the buss. I suspect this is why it cleared up later.
Scary that the switches could fill with water and then soak in. Hopefully water there dropped down without getting into other things.
NYCBD
New York
Subway
Water Intrusion from washing with garden hose.
I have the exact same issue, and coincidentally (or not) the same model (2 Door Black Diamond) and I’m located on Long Island. My electronics still work but the screen is all cloudy now. I brought it in to have it fixed but just washed my car this weekend and the same thing happened with the water leaking through the aux switches and down into and behind the hero switches. I wonder if the hero switches are supposed to be sealed…seems like a real flaw that they aren’t and there is a ton of electronics right there that can easily get drenched. @Ford Motor Company is this issue wide spread? A bit upset that I had it in to be serviced and this issue is still occurring. And now my screen is getting more damaged.
Ford Bronco Electrical Systems Failure, Caused By MIC 2.0 Leak IMG_5411
Ford Bronco Electrical Systems Failure, Caused By MIC 2.0 Leak IMG_5412
