Jazer
Jessica
2.7 OBX
To those that have installed these coilovers, lets see some pics!
I got my Eibach 2.0s through Panda (great experience). Installed over the weekend!
How much is everyone seeing these settle?
I'm on 33s and intend to stay that way til these need replacing so I didn't want to "shrink" them too much. I turned them down to be pretty close to max low - I left the rears with a few threads for adjusting if needed, and front set to be close to even, a lil lower to retain a small amount of rake. Was at about 3/4" difference immediately after install.
Pretty happy with the adjustment.
Ford Bronco Eibach Coilovers NOW AVAILABLE! IMG_20240825_184605
Caleb@PandaMotorworks
Caleb
St Louis MO
Turned out great! 😍 Thanks for sharing!
moab_b2
Jason
96 FZJ80
Is a rear track bar relocation kit needed with this lift maxed out?
moab_b2
Jason
96 FZJ80
Ordered last night with UCAs. Cant wait to get them installed.
moab_b2
Jason
96 FZJ80
It is not required!
Just looking at the kit with Zone UCAs and notice the picture has a ball joint installed. Is this correct or is the stock ball joint pressed out and pressed in to the zones?
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Ball joint is pre installed from Zone
Caleb
St Louis MO
We have 2 sets of Eibach Coilover WITH HD Springs IN STOCK!
Willing to do a great of a deal on those 2 sets, first come-first serve!
Non-HD coilovers in stock and can do a good deal on those as well.
Shoot me a message :)
BuiltByTrav
Jacob
Knoxville, Tennessee
2023 Bronco
mpeugeot
Needed no, worth it, yes. In my case, I did both the track bar relocation kit and the adjustable track bar. It does help.
If you want to really get everything dialed in right, you would also want adjustable rear control arms to improve the rear pinion angle. I didn't initially, but I probably will eventually.
Caleb
St Louis MO
Still 1 set of HD left if anyone wants it at a discount!
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Another Day...Another Set of Eibachs Installed!
HD Kits in stock still :) I was able to snag a couple more!
I have a Wildtrak with maybe a hundred pounds in cargo. Will the HD set ride too stiff without added bumpers/cargo? Or will the 2.7 up front and 100lbs of cargo in the rear be ok?
St. Louis
HD will be perfect! Not to stiff and a lot of Adjustment range to have minimal lift or max!
