- First Name
- Kevin
- Joined
- Oct 18, 2025
- Threads
- 15
- Messages
- 344
- Reaction score
- 385
- Location
- Bay area California
- Vehicle(s)
- 2026 Badland 4-dr Manual
- Your Bronco Model
- Badlands
I finally installed mine last week. I also swapped out the stock muffler with a smaller Steeda muffler so I had lots of room between the muffler and the bottom of the storage compartment. I am not worried about heat transfer. I was going to add sound deadening to the Bronco cargo area, but decided to wait since it looks like once it is installed, there is no getting rid of it (way too sticky). I am happy with it. It is definitely bigger than the stock plastic compartment.
Anyway, here are some suggestions I wish DV8 would consider for future products:
a) add a gasket between the storage bin and the support frame and also add a gasket between the support frame and the Bronco metal body to keep out water. I may end up using silicon caulking to achieve the same result but but it will not look pretty.
b) add an optional locking metal lid that attaches to the support frame
c) add an optional light inside so you can see contents without needing a flashlight or other light source
d) add sound/temp insulation pads for storage bin ends, currently they are left without any covering
