Driving with Front and Middle Panel Open
Chewy77
Chewt
Atlanta
2025 Bronco Sasquatch-Lux
Is this safe to drive with Front Roof and Middle but keeping rear panel on?
Chewy77
Chewy77
Chewt
Atlanta
Thanks for quick reply - did know if recommended to take it all off to drive. I want to just take off the front and middle panels but leave rear panel on.
RobWTX
Rob
I heard that a lot of people do that, or reverse, remove the rear and leave the seated area tops on for less direct sun.
Soft top FTW
Bronco Toad
Todd
Central Ohio
2022 Bronco Badlands 4dr Cyber Orange
I have pulled the taken the front off with just to middle and back, I have pulled the back and left the front and middle. I have also pulled the middle and left the front and back on. I have also just pulled the driver's side off and left everything else. Modular run it how you would like.
Rocky-in-AR
NLR Arkansas
2023 Bronco
I have a bestop skyrider and that is how it is designed. You keep the back portion on and install the skyrider to replace the front and midtop. Works great.
PNBLWZD
James
CA
Hellcat Challenger, Mbz S550, Mbz GLE63s, Silverado SS
If running only the front panels, what holds them up? Doesn’t the rear shell support them?
Chewy77
Chewy77
Chewt
Atlanta
I got hard top
Thanks for the tips -appreciate it
JSW377
J
25 Bad Squatch
I’ve been driving that way for over 2 months now. Only issue is your MPG is going to suffer.
I even left the roof rack on.
Merry Christmas all🎄
JungGravy
Jung
GA
'25 Brawnco, '22 Cheap Bland Jerokee 4xe, Kia Grocerygetta EV
one caveat: Ford says not to drive with only the middle panel off
1979
Ben
Baltimore, MD
2023 Bronco Raptor
They all still attach except the rear most latches. I have run the top like this times.
tofudrifter
Los Angeles
RAM
So it literally stays on tight? We drive 80+ in LA.
I wud love to just take off front left front right. Or perhaps in a pinch front driverside.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Tops stay secure in all combinations. I have run many times in all combinations at highway speeds.
