Drivetrain Chirping/squeaking Noise
PNBLWZD
James
CA
Hellcat Challenger, Mbz S550, Mbz GLE63s, Silverado SS
Hi all. I started noticing a chirping noise from under the Bronco at low speed (<20 mph) over the last couple weeks. 2024 heritage ltd with 850 miles.
Frequency changes with ground speed, but not engine rpm. Develops after about an 8 mile warm up drive to and from work. 2H or 4A makes no difference. Rolling in neutral makes no difference
Frequency of the noise is rapid, faster than tire rotating speed, so I think it’s driveshaft related, dry u joint, differential or…?. Stops when truck comes to a stop.
Video sound clips attached, but faint. Please have a listen and see what you think. Thanks!
helifino16
Ron
Mount Sinai, NY (Long Island)
Check the 'GOAT mode' selector, you may have chosen this (specific to the Heritage model) instead:
Ford Bronco Drivetrain Chirping/squeaking Noise 1738163156111-xt
PNBLWZD
James
CA
That’s pretty much what it sounds like!
Taking to dealer tomorrow
PNBLWZD
James
CA
Update: Dealer service dept replicated the noise on the street and then listened while up on the rack to locate. Coming from inside the transmission apparently, waiting for the Ford tech line to authorize replacing transmission.
I haven’t read anything about transmission issues on here. Am I just lucky or…?
Ducati1098
You’re just lucky. Never heard any kind of a noise like that from a 10 speed
Bronco Libre
Chicago
2 dr Black diamond
Any new update on this? Did the dealer replace the transmission?
I just started to get that same exact noise on my 23 black diamond. 13,850 miles
Only happens after it has been driven a few miles.
