DONE! I have re-drilled rear shock mount 2” higher, =more clearance and 2” lift.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
I figure the shock mount is so close to the tire that it won’t be much of a problem???
Exomodo
Ryan
Marquette, MI
Ranger
I have thoughts on how to do this correctly, but litigation keeps me from expressing them. Everyone is free to drill whatever they want, but I would suggest not and figuring out a way of making things stronger instead of more swiss.
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
Anyone see any issues with repositioned rear lower shock mount bolts???
I plan to drill new holes 2.5” higher up and then reinstall the shocks. This should lift the rear about 2.5 inches. If I like the way it rides, then I'll cut the same 2.5” off the bottom of the ridiculously low shock mounts. Then the clearance will be the same as the trailing bar mounts on the axle itself.
Any thoughts before I get the tools out?
Isn't better just to get spacer instead of messing around with the previously engineered shock mount?
It looks like too much work and risk when you already have aftermarket options to lift the Bronco.
Gtrekker
Gary
NJ
I am optimistically curious and even intrigued. Please keep us posted... Thx
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
I’m failing to see how you would do what you’re describing? It certainly appears that the upper shocks mount in a strut pocket that’s part of the frame, meaning you’d have to cut out the entire pocket and fabricate a new upper mount. You might want to put down the Dremel…
No, that’s not what he’s talking about doing at all.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The reasoning is you want as little stuff hanging below the axle as possible. Look at how the big boys do it.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
Sorry, I misread it the first time. I just had knee surgery and can’t go look under my Bronco just yet.
Looking at the other picture it should work, I’d want to weld in a gusset to strengthen the mount, and probably weld some thick flat washers to the outsides of the holes. it’d be great if a 2” rear lift could be accomplished with simple holes in the bracket.
MaverickMan
Shane
I do love this. Reminds of a SOA lift on a cj/yj or a shackle hanger flip and washer stack lift on a FSB or ranger. Free or near free lifts that improve things in the chassis are awesome. I would weld-in and reinforce the mount while you are cutting it for sure. Why not?
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
Somebody has to be first, go for it. I question needing 2.5" of lift, but I don't know what tire size you want to run. It totally makes sense, and I'd look into doing it. Not having a Bronco to look at, I don't know how feasible it is. But, nothing at all wrong with the idea.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
That's exactly what I had in mind!
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Here's a couple pics of the area.
