Do the front hubs lock in using vacuum?
DemonGT
Dan
Wisconsin
2022 Badlands
Do the front hubs lock in like on the F150's using vacuum or is it a different set up?
Ducati1098
Bronco raptors use IWEs like F150’s. Regular Broncos do not. They just have normal hub/bearings.
Fordified1
Bob
Mid South Texas
IWE? I’m acronym challenged lol.
So Broncos hubs do not unlock?
Ducati1098
Integrated wheel ends. Those are what uses vacuum to lock/unlock the hubs to the halfshafts on F150 and Bronco Raptor.
Normal Bronco hubs do not unlock. The halfshafts are splined to the hubs at all times.
RagnarKon
Ford Bronco, Escape, Focus
To add onto what @Ducati1098 said...
Some Broncos have a FAD—front-axle disconnect. All Broncos with open differentials have a FAD, and I think the Broncos with an electronic rear locker and the part-time transfer case may also have a FAD... but not 100% sure about that.
If you have one of those FAD-equipped Bronco and try spinning the front wheels while the vehicle is off the ground, it may seem like the hubs are not locked. But that's not the case, it's just the FAD doing it's thing.
Fordified1
Bob
Mid South Texas
You’re kidding right?
mcinfantry
Lee
Louisiana
Badlands 2 door
Ducati1098
All except one. 4.27 doesn’t have a FAD
4.46 can also come with or without it. I have no idea what determines if it gets it or not though.
Final drive ratioFeature codes (SDR codes)Axle codesFuel economy codes (SDRType of axle/differential
3.73EGAJBEGKADC7AAFOpen style front differential - M190 STD - aluminum carrier and tube assembly with FAD, 7.5” ring gear
4.27EGAMEOpen style front differential - M190 STD - aluminum carrier and tube assembly without FAD, 7.5” ring gear
4.46EGADROpen style front differential - M190 STD - aluminum carrier and tube assembly with and without FAD, 7.5” ring gear
4.46
4.70
EGADR
EGAA6
EGKAHC7AABElectronic locking front differential - M210 - Black cast iron carrier and aluminum tube assembly without FAD, 8.26” ring gear
Fordified1
Bob
Mid South Texas
Fordified1
Bob
Mid South Texas
front axle disconnect
Thanks.
Seems like they all would have that in the quest for better fuel economy. But I hope my Bronco doesn’t have it. just one more thing to quit working at the worst possible time. I put warn manual locking hubs on my Excursion years ago because the auto locking hubs became unreliable.
Fordified1
Bob
Mid South Texas
4.46
4.70
EGADR
EGAA6
EGKAHCElectronic locking front differential - M210 - Black cast iron carrier and aluminum tube assembly without FAD, 8.26” ring gear
Maybe the 4WDA option?
HPNQ420
Wauwatosa, WI
QUOTE
Advanced 4x4=no FAD
