Do I need regear the transmission?
Gideon_nunley
Gideon
2023 Bronco
I have a 2023 big bend 4dr v6 automatic non sas. Im wanting to lift it and put 37’s on it do I need regear the transmission?
also what offset should I get for the wheels?
BigMeatsBronco
Allan
2021 FE 2 door
???? post like this are amazing ... do people really buy a bronco and have no clue how there set up and where the Ring and pinion is at? brown cows don't make chocolate milk buddy.
glad your here to learn.
the ring and Pinon gears in your axles NOT the transmission, can be changed as you suspected.
I recommend a trip to the spicer website.
Dmorty217
Derek
Venice FL
Camery
You can get larger axel rings and pinions. You have a non sas so I’m not sure if that’s the m190 axels like the non sas black diamond has or if it’s the m210 axels. If it’s the 190, you will have to replace the axels which is going to be costly, unless someone came out with gears for that axel (I haven’t been able to find anyone)
Gideon_nunley
Gideon
2023 Bronco
I’m new to all this so that’s why I’m asking, gotta learn somehow
mcinfantry
Lee
Louisiana
Badlands 2 door
Tl:dr
You don’t need to regear the transmission
you couldn’t afford it if you wanted to
userdude
Denton, TX
2023 2dr Badsquatch
You got a lot of work to do to get 37's on a Big Bend. Basically you need space (2+" of lift) to fit the tires under the wheel wells and heavier duty front axle (M210) with I would think 4.7 gears. There's a Ford Performance Bilstein lift I'd check out (5112's?), since that could be covered by your warranty when installed by Ford/ASE Red mechanic. There's a myriad of other things you'll need to do, as well (it's just never that simple).
Of course, a regear with axle swap is expensive. I would gather in the $7-10k range installed. You might look more at 35's, or 33's if you have 32's.
userdude
Denton, TX
2023 2dr Badsquatch
Is there a gear-only upgrade for an M190 that'll work for 37's?
popo_patty
Caleb
Sacramento
Loool at the previous responses.
I don’t recommend 37’s to anyone that isn’t using them.
That being said, it’s not cheap, it’s not easy, and it affects your daily driving quality to an extent. If you want to DM me the exact details of your vehicle, what terrain you have around you and why you want 37’s as well as what kind of wheeling experience you have. I’ll try and help get you started.
You seem somewhat new (which is awesome!), we all start somewhere. Usually the first bit of advice I have for new wheelers is learn your vehicle as is, learn the basics. Figure out if getting pinstripes, cleaning mud, and banging on rocks is for you before dumping money at it.
Learn about trail etiquette, taking lines and performing some basic self maintenance on your vehicle as well.
All that being said, hit me up. I’ll point you to a couple different options.
Aonarch
Jack Hoff
MT
Why do you want 37s?
userdude
Denton, TX
2023 2dr Badsquatch
Hope you're paying attention, except for me there are several experienced members who've commented already.
popo_patty
Caleb
Sacramento
I always look for your comments cause that’s how I know a thread is getting good ;)
Disciple Mike
Red Oak, Texas
Silverado 1500, Bronco, 600RR
Don’t feel bad about being new to something, everyone has to start somewhere. There’s endless accessories and modifications to make, so it’s pretty important to have an end goal in mind that you’ll be satisfied with and will meet your needs and wants. I think you’ll find as well, the more research you do, the better questions you’ll be able to ask. Enjoy the process!
