Zakm
Zak
Jacksonville, AR
I don't have a better photo of it with the top off and the molle installed yet. I just got it on yesterday. I'll circle back once I do though!
What front light bracket did you use on the modular bumper?
GlueBoy
GlueBoy
gluefactoryoffroad.com
21 Bronco
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
You select from which lightbar you have. I run the 30 inch stage 6 from Diode Dynamic. I'm pretty sure I just bought the bar and brackets from the website.
Got mine from the same place.
I particularly like how you could customize what you want when you pick a mount.
The passenger side mounting point of the light bar just failed yesterday, but Diode is sending me a new side piece to replace it with. Meanwhile, it's held up with a bungee cord.
Ford Bronco DIY 2 door molle panel 20230317_181819
GlueBoy
GlueBoy
21 Bronco
I made a few new brackets as I wasn't too fond of it sticking out so far, but the facia keeps it from sitting back more. Which was a bummer. But overall, good bracket!
Giddyup Buttercup
2022 Ford Bronco
Nice work. I was thinking of making Molle panels until I found that Molle is not a quick attach system.
How much would not having the Molle holes reduce the price?
GlueBoy
GlueBoy
21 Bronco
You're just looking for a plate with no molle or 1/4 holes? Just the mounting holes and associated brackets?
mikeeshim
Los Angeles, CA
Wouldn't object to having a 3rd mounting bracket along the bottom. The point closest to the tailgate could use a little more support IMO.
GlueBoy
GlueBoy
21 Bronco
I came to the same decision, you can see it through the glass just left of the decal. I already modified the plate to account for it.
Ford Bronco DIY 2 door molle panel 20230509_090915
mikeeshim
Los Angeles, CA
Ok I'll take it. Stop twisting my arm.
Giddyup Buttercup
2022 Ford Bronco
Correct.
