Broaddict Trail Deck in a 2-Door? MOLLE Panel Compatibility?
gehrm
2025 2-door Badsquatch
Hi all,
I'm a 2025 2-door owner with the rear seat delete and was inspired by these two threads:
I have three questions:
  1. Has anyone successfully adapted the Broaddict Trail Deck to a 2-door Bronco?
  2. Has anyone confirmed compatibility between the Broaddict Trail Deck and cargo-area MOLLE panels?
  3. Does the Trail Deck work with the Tailgater table or are there clearance issues?
The 2-door retrofit looks feasible based on dimensions and mounting points, but I'd like to hear from someone who has actually done it before ordering.
My bigger concern is MOLLE panel clearance. From the photos and dimensions I've found, it appears the Trail Deck sits very close to the quarter panels, and unlike the OEM slide-out tailgate, any trimming required for MOLLE panel compatibility could be much more substantial.
The OEM slide-out tailgate remains a viable option, but the integrated storage drawer in the Broaddict system is particularly appealing.
If anyone has firsthand experience, photos, measurements, or lessons learned, I'd appreciate the input.
Thanks.
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
They are coming out with a 2 door version, planned in June.
On the molle panel, I don't know. I have side molle panels and will see what I can do when I get the TrailDeck.
It has been posted elsewhere that the tailgate table will not work with the TrailDeck. I will see if I can possibly raise the table for clearance.
Again, 2 door TrailDeck is planned to be out in June.
gehrm
Thanks. Will be curious to see the dimensions of the 2-door version, but think it is going to be smaller than retrofitting a 4-door. I thought I did read though that they designed the 2-door to work with side molle panels and with a redesigned handle. but tailgate table clearance issue likely still present. I know Mountains to Metal also made a pull out tailgate for the 2-door, but I wish someone would make the seat delete version of all of these (or have the 2-door seat delete conversion kit factory made for the 4-door version).
