Broaddict trail deck installed
Run3gun
Anthony
2023 Bronco
Just installed my Broaddtict trail deck
Great product do be aware that it will not work with most tailgate tables but broaddict sells on that’s compatible. Will update once it’s been installed Anyone interested in purchases can use the 5% off affiliate code below.
https://www.broaddict.com/discount/ANTHONYRAMIREZ?ref=uouailrt
Ford Bronco Broaddict trail deck installed IMG_8312
Ford Bronco Broaddict trail deck installed IMG_8314
CitrusBronco
Everglades
Citrus county, FL
Everglades
How’s it look pushed in with the seats folded down, how flat does it make it?
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
I just installed mine as well. I used the boat decking stuff for the factory floor underneath. I don’t want to look at my sound deadening. Came out great. Added the broaddict shelf at the same time. I’m waiting on Broaddict to send the new tailgate table that works with the traildeck. Guess they are in high demand.
Run3gun
Anthony
2023 Bronco
Thinking about the shelf myself lol!
Got any pics to share ?
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
I like the drawer, but I don't like that you have to remove the carpet. Its too bad really, because other than that I'd be really interested.
EOD98
Las Vegas
Broaddict is developing a carpet
Run3gun
Anthony
2023 Bronco
It’s not really a carpet just removed the trunk pad this need to be removed for the slide and the seats to be level. You could buy some after market carpet or felt to put down or even raptor line it . Endless possibilities. Left mine bare and doesn’t bother me not even a
Ford Bronco Broaddict trail deck installed IMG_8344
little bit . I also insalled a BLUETTI charger 2 in the cutout that needed to breathe so the slide deck for me serves many purposes.
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
I just installed mine last weekend as well. It was a very quick and easy install. It took me longer to breakdown the carboard box for recycling than it did to install.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
If you remove their handle and replace with a soft handle will it then work with a tailgate table?
Run3gun
Anthony
2023 Bronco
Same !
Run3gun
Anthony
2023 Bronco
Maybe you would need to measure
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I wish Broaddict would come up with an updated design which is 1 to 1.5in shorter to allow compatibility with existing tail gate tables. I would buy one immediately, but can't justify losing my existing table ($250) then spending to $$$ buy this version and another tail gate table. Odd that they didn't consider this during the initial design. There are likely others similar to me.
Run3gun
Anthony
2023 Bronco
Found that out the hard way I agree they would sell a bunch more if it was just a smidge shorter
murphtron
T
Berkeley, CA
I’ve seen other reviewers where people just replace the pullout handle with a soft grab handle to make it fit with existing tables. Now I remember. Been awhile since I read or watched in YouTube.
