Disabling Auto Headlights
Desert_6G
Phoenix, AZ
Ranger
Has anyone figured out how to disable the auto headlights so you can control the headlights manually. I can't stand that they come on automatically when you first turn the car on.
faziorf
'21 2DR OBX AMB
Ford Bronco Disabling Auto Headlights 1636228285021
it might just reset to auto after you change it though.
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Since it apparently resets to auto.... You can also open the hood and pull the connector to the headlights. This process will differ depending on whether you have Signature or standard lights. When ready for a dash of light, open the hood and plug back in.
I will probably try and set the connector to some type of switch that is easily accessible inside the Bronco.
Otherwise maybe something that can be overriden in Forscan?
Desert_6G
Desert_6G
Phoenix, AZ
Ranger
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Don't have the ability to go out to my Bronco right now and look.....
Trashman15
Ben
Missouri
You can go through the menu on the dash and actually turn the daytime running lights off. I had to get a replacement headlight shortly after I took delivery and all the replacement lights I got from the dealership had issues with the amber and day time running light so I turned that off to avoid the "winking" my bronco was giving people.
mmaturo
Celebration, FL
C8, R8s, Q7
For the high beam thing you can just pull the lever like for flashing high beams and turns the auto function for the high beams off for that drive. There is also a setting in the settings menu under lights for it that maybe defeats the turn on at start up but that part doesn't bug me so haven't tried it
AK SNO RIDER
Ty
Alaska
glamosaurus
Hope
New Hampshire
Ford Bronco
Total Bronco newbie, haven't had it for a week yet, and I've accidentally blasted so many people with brights thanks to the auto headlights. (I live in the dark dark woods of NH.) LOL. I will be checking out to turn this off in the settings later today.
HeliPilot
Kenny
CT
2022 2.7L SAS
It's under Settings, Vehicle, Lights
