Disable Auto Start Stop on 2024 Bronco ?
BRMarshall
B.R.
Katy, TX
Has anyone successfully disabled auto start stop in a 2024. I've used Forscan to make changes on my 2024, but I'm not able to get the auto stop start modification to work. Any suggestions?
Ducati1098
Forscan won’t work for 24.
Buy a programmer that will disable it or buy the autostop eliminator.
BRMarshall
BRMarshall
B.R.
Katy, TX
Thanks for all the suggestions! Is there a chance that there will be Forscan update for 2024? Or has there been some change that has rendered this no longer possible?
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
The ProCal doesn’t fix it either. Perhaps there has been a change.
Sandy56
Tennessee
2022 Outer Banks Sasquatch
F
If you have the tow package, insert a 4 pin trailer hook up that doesn't go to anything (clip the wires), works on a 23.
From my understanding, this also eliminates the blind spot monitoring too. Just to keep that in mind
Ducati1098
Unlikely, it hasn't worked since 2022.
BRMarshall
BRMarshall
B.R.
Katy, TX
OK, what's the thoughts on ProCal, sounds like it currently does not work for 2024's. Is it likely there will eventually be updates that will make it compatible for 2024's?
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
No idea if this has any effect on AutoStart/Stop but for about $1000, the loss of running less than premium gas and most likely MPGs, I wouldn't do it. But than again I'll never understand trying to squeeze more horses out of a Bronco, it's not a Mustang, but everyone has their own desires.
Again I say, for 100 bucks the AutoStop Eliminator is a slam dunk and it allows you to turn it on at any time if you really want to.
