Differential cover upgrade - Ford Performance vs. ARB
Gluestick
Josh
Nashville
instagram.com
FP but it did rust and flake off the paint in under 1 year….
Well that stinks. I have not had that issue so far at roughly 2.5 years. Meanwhile magnaflow doin its best to turn orange on all the pipes. Are you in a high salt area (snow)?
HertiageMerica
Chester County, Pennsylvania
Ford Bronco HE
Oh yea ! Brine too however I do clean the underside pretty regular. I know another that had same issue
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
There's a guy whose handle is carbon ? something did a good write up on the FP. Search for it in broncos 6G
I'm guessing you're referring to @CarbonSteel? He's very knowledgeable on most things lubricant related.
OP, Banks has a series videos on rear differential covers explaining their roll in lubrication and cooling. These won't answer your FP or ARB question, but I found them interesting. Here is one of them...
Rockledge
Darryl
Fayetteville N.C.
2022 Race Red Sasquatch , 1951 Willy's M-38
I went this route. Found this on Ebay for $100. Made by Motive Gear.
Looks good. I find this at $ 155. you scored !!!
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I used the FP diff cover. Works okay so far, use the OEM brake posts no problem. Also take the magnetic drain plug from the OEM covered and added to the FP cover so now you have two magnetic plugs. There's a guy whose handle is carbon ? something did a good write up on the FP. Search for it in broncos 6G
I am a little confused. I am pretty sure the OEM cover does not have a drain plug. Are you referring to the OEM fill plug to move to the FP cover?
Hammerli22
Isuzu Rodeo
Yea that's what I meant
CarGuy
New Jersey
2023 Ford Bronco
The Banks cover is an interesting design - e.g., ram air cooling, integrated o-ring, etc. I enquired about it for a Bronco and they have no plans - likely due to the ram air portion of the cover hanging lower and would be a disaster off road.
