did the kicker sub swap.. not worth it.
Darren D
Darren
Lake Grove, NY
2023 Bronco Raptor, 2023 VW Atlas Cross Sport R
mmm, is that something that can be under with Apple CarPlay stuff and Apple Music?
Right in your Spotify settings. Settings/playback/equalizer
ttt123
ttt123
brian
Lapeer mi.
Bronco, GMC evolution, Chevy corvette
Sometimes you just need to step outside of the … box 😉 lol
not happy with the 8” so going another route. I’ll update later.
Also plan on getting rid of the complete 8” set up. Amp, wire harness, box and sub. All brand new.
Ford Bronco did the kicker sub swap.. not worth it. IMG_0619
Ford Bronco did the kicker sub swap.. not worth it. IMG_0620
Ford Bronco did the kicker sub swap.. not worth it. IMG_0622
Mjasi3
Chicago
well thats interesting. quick removal!
ttt123
ttt123
brian
Lapeer mi.
unless you meant quick removal for sub box.. in which case yup ☺ if i need the space just unplug and set the box in the garage 👍
Mjasi3
Chicago
exactly what I ws thinking - remove when you need the space... mmm.
Will be looking forward to your full write up of what you did. Very cool!
ABorges
Art
Fresno CA
1973 F100
oh I wasn't expecting eye ball shaking. like I said, I was just expecting a bit more then stock and .. it just doesn't seem like it did that. again.. not bashing the mod just sharing for me.. I would say to someone whos going down this road.. invest in something other then that factory enclosure.
The kicker's quality is much better nowadays, I bet the air space in your enclosure is off.
ttt123
ttt123
brian
Lapeer mi.
i did end up playing with it some more and was able to tune it a little better and get a little more but still wasn’t happy. This set up will allow me to have options.
Ill post pics up tomorrow.. almost finished.
ttt123
ttt123
brian
Lapeer mi.
Soldered in the Wires, went back to that kick amp. Didn't like the sound of the sundown amp.
This kicker can push these two Memphis 10” easily.
sounds amazing
Ford Bronco did the kicker sub swap.. not worth it. IMG_0625
Ford Bronco did the kicker sub swap.. not worth it. IMG_0626
Ford Bronco did the kicker sub swap.. not worth it. IMG_0627
mpeugeot
I finally got my Kicker 48TRTP122 off the floor of the Bronco and it sounds glorious.
Ford Bronco did the kicker sub swap.. not worth it. IMG_20250201_140839529_HDR
Ford Bronco did the kicker sub swap.. not worth it. IMG_20250201_140900979_HDR
Ford Bronco did the kicker sub swap.. not worth it. IMG_20250201_140845449_HDR
jcgcbns22
Caleb
Nova Scotia, Canada
Really doesn't matter which version of the CompRT you got (there's a 4 Ohm and 2 Ohm) - the 500.1 is rated down to 1 Ohm, so you'd probably wire your voice coils in parallel either way. If you wired them in series, even if you had the 4 Ohm version, it wouldn't break anything, but it would be quiet, as that 500W amp would be down to like 50W output against so much impedance. So maybe???
My Kenwood amp is only rated down to 2 Ohm, I have the 2 Ohm version wired in series for a 4 Ohm load.
Running Kicker Key 500.1 (500 watt 1 ohm) into Rockford Fosgate PUNCH 12" box (1 ohm) and it sounds awesome. Changed stock speakers in kicks (6.5) and dash (4). Box is on waterproof detach so if I need the space easy to store in garage. Budget upgrade as I has the sub from prior vehicle.
