Dead Pedal Riser?
KT_bronco
Jon
So-CAL
Transit Connect Cargo
My short leg doesn't reach the dead pedal. Any recommendations on an extension?
I looked around the net, but only found custom mods using wood blocks.
RagnarKon
Ford Bronco, Escape, Focus
Well I was going to say “2x4 and construction adhesive”, but @HighVelocity already beat me to the snarky response.
Realistically though… it’s probably going to have to be a DIY solution.
Techun
Pa
BD, 2.7, MIC, 4dr
Can you reach the important pedals?
helifino16
Ron
Mount Sinai, NY (Long Island)
Something like this may come in handy to help get your feet to the rest stop (and Pedals):
Ford Bronco Dead Pedal Riser? 1719419012964-9o
KT_bronco
KT_bronco
Jon
So-CAL
If the platform shoes don't work out, I'll give this a go. Plenty of forum members willing to turn the wheel I'm guessing.
JerryC
Memphis
2022 Bronco
I don't know of anything pre-made for that. I don't believe that would difficult to make.
Making it safe and not ugly are two concerns.
You don't want it coming loose and going under the brake pedal for example.
If you found some thick rubber and glue it, that might work.
As funny as the shoe picture is, going to a shoemaker might not be a bad idea as they may have the materials and expertise to add to the dead pedal.
Dlars99
Dan
2023 Black Diamond
You could modify this thing
Ford Bronco Dead Pedal Riser? IMG_2281
KT_bronco
KT_bronco
Jon
So-CAL
Yeah good suggestion, I was just under there the other day running wires. I think there are two studs out of the fire wall. I'll have to look again. Either that or I'll remove the cap off the dead pedal, there are two bolts there. I'll try to figure out something there.
@JerryC I was thinking of using some rubber of some sort and glueing it as well, but you bring up great points about safety, and aesthetics.
HoosierDaddy
__ Eric
:unsure::unsure::unsure:
Scoot the seat forward and adjust the steering column while you're at it.
