Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
da_jokker
Jeep Wrangler JKUR
There's no way I'd pull my bumper back off unless I absolutely had to (pita), It almost seems like having something that would slide into that big front hole in the frame with flanges on it would be a great universal support. It would push out any bumper by 1/4" bit any side load would be distributed through the whole front frame horn.
I almost pulled a trigger and ordered the LOD but I couldn't find any. Now that tricky has something, I may wait to see the $ of those.
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
I have a set of the LOD plates in a box that I was dreading to install, but now I want Tricky's after seeing that prototype.
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
Sewie
Sean
San Jose, CA
74 Bronco, 22 Bronco BL Sas 4D
he also broke a tie rod at the end. I wonder if he included that in his own video?
He did. And it was an Icon tierod. Broke at the stud going into the rack. /hijack
Tex
Cliff
San Angelo
That would be a good way to strengthen the area, but without any kind of gusseting on the back side of the bumper pads, you're relying entirely on the bending strength of a flat flange coupled with the bumper pads, meaning thickness would be your only ally in strength as opposed to gusseted support. You'd also have to figure out some way to recess the flange enough to contact the bumper pads, cut the end of the frame flush with them, or use the flange as a standalone mounting surface.
The alternative would be to slide in some tubing pre-drilled to interface with the bracket that OP is making and basically sandwich the frame between them.
shawn6107
Shawn
Tuttle, OK
Ford F250, Ford Expedition Max, Chevy Silverado
Well, I’ve gotten away from this thread since I’ve been waiting on my LOD brackets to come in. I started taking all the wiring off my bumper last night so I could tear into it and put the brackets on tomorrow since they finally came in.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 74808870-4CFB-4B52-A86D-4F3D6B279D52
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 051D06FF-0F3D-475B-8A1F-6B29BCB33B4C
as you can probably tell from the pictures, my mount is pulled forward and twisted a little bit. I planned to take everything off tonight to bend the plates back and mount the brackets. However, after catching up on this thread, I’m afraid that the slots on those brackets are a problem. Those should be holes and not slots. TD will be able to tell us after he gets his off again, but I would bet that the slots slid over the bolts and allowed the bracket to move. Now I’m considering welding the washers onto the bracket to try and help hold it in place. That’s probably not a heavy duty enough fix, but I’m not sure what else to do other than build my own brackets or weld the whole thing on. I’ll think on this more today and try to do something tonight.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
What would make this a super model of the year is if it had the same dog ears at the bottom as is the top.
It's on the table depending how the prototype fits. I forgot to order the weldnuts so I won't be getting into it until this weekend now.
I think just my mount is tweaked this time, one corner definitely is twisted up higher than the other. I'm going to run with it a bit longer while I plan out a bumper but I'm going to beef up the RC mount a bit because it's too light duty.
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
shawn6107
Shawn
Tuttle, OK
Well it was a little worse than I thought. The bumper plates are off a bit on the passenger side especially but the bigger problem is the winch mount.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 429EF050-A9D6-495B-A2A4-3218DEC767CB
It’s twisted pretty bad. No fixing that.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 89F821E5-A01D-4F91-BF64-95A328F6F4FA
However, I called Rough Country, they answered right away and they’re sending me a new one tomorrow. Just wanted pictures of the bent mount. Service was much better than I expected.
The bumper plates were pulled out on that side too. I bent them back as best I can but to get them all the way back I’m going to have to use the frame brackets to pull them back and hope that works.
Tricky Dick
Dick
PNW
Nice! I didn't even think to try that.
Haven't got mine off yet, waiting for the weldnuts for my brackets so I can do it all in one shot.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
I was looking forward to getting myself stuck soon....I'll be installing the LoD brackets but I'm guessing that'll just be a bandaid until Tricky gets his parts ready for shipment up to Canada.
Tricky Dick
Dick
PNW
The prototypes are welded up and ready to test fit tomorrow. I'd love to have a first run to sell at the Stampede in 2 weeks but it's going to be tight.
techdisaster
Not a Bronco
I’m interested in a set.
marklio
Washington
Focus RS
I'm also interested. Depending on how close to Seattle you are, I'd be happy to pick up locally and test fitment.
Status
