Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Felix808
SRV CA
That sucks TD. Hope you get it sorted in time.
Have to say I am glad I changed my mind on the RC high mount 🤠
Tricky Dick
Dick
PNW
www.TD-Distributing.com
For anyone considering it I wouldn't rule it out, just don't consider it a complete kit.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
BroncoTrail
Salt Lake City
2021 Badlands Sasquatch Lux
@JcrOffroad may want to follow this thread.
I have the JCR winch plate on order right now along with a winch. I'm trying to find out if I should be concerned about something like this and if I need to add reinforcements.
V1Rotate
Brevard, NC
2022 Wildtrak
It’s almost identical in the way it mounts to the vehicle (just uses the factory tow hook bolts) so I’d say if someone can bend the frame using the RC mount then I’d be looking at reinforcing it for the JCR mount too
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
V1Rotate
Brevard, NC
2022 Wildtrak
@VoltageDrop when you say “considering how high above the frame center line it mounts” what does that mean? I assumed the RC is mounted below the frame center line as it’s so low. Just trying to learn the lingo. Thx
The rough country high winch mount in question positions the winch/fairlead considerably above the frame line and particularly the mounting points for the mount itself.. creates a good bit of leverage particularly when winching down (nose high)
Tricky Dick
Dick
PNW
I would say the LoD or Havoc plates would be cheap insurance. The $100 would be well worth my time alone having to go back and correct this.
01tundra
Middle TN
2003 Toyota Tacoma / 2021 Nissan Titan XD
Well back in the day we never bought aftermarket bumpers either. We would take off the stock bumper, extend the frame horns outward. Mount the winch plate on, then made the bumper around the winch. Sometimes it came out looking cool, sometimes not, after a few beers everything looked awesome. Either way it took a beating and kept wanting more. LOL!!
That's exactly how I built the hidden winch mount for my Tacoma, it's not going anywhere and is still technically "bolt-on", but I sleeved and plated the frame.
Those bolt-on winch mounts for the Broncos are so cantilevered out and above the bumper attachment points I can't see how any upward pull would not bend something, especially with a 5K rig that's stuck good. I've had to make dead pulls with the winch point 12' up in a tree pulling at a 45' angle before........
I've always built my winch mounts so the spool was as close to centerline of the frame rails as possible, I realize that's a tall task on the G6's......so we ride with friends with winches and carry a Bubba Rope :).
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount s46OLJu
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 5vL07bH
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount J5Plc1i
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount AWqi8Yk
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount iW7eCF
murphtron
T
Berkeley, CA
Oh I get it. I actually thought you were referring to the RC hidden winch. Makes sense now.
Status
