cr117
cr117
PNW
Bronco, EV6
cr117
cr117
PNW
Bronco, EV6
Made some progress on this little project tonight. Cells have been top balanced and the box is mostly built, just need to add some feet to the bottom and a cover on top. The base panel has a pass through for the wires coming off the cells that’ll run down to the BMS mounted on the underside.
Ford Bronco Custom Dual Battery Build IMG_5547
Ford Bronco Custom Dual Battery Build IMG_5549
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
What a cool project! Can’t wait to see how it turns out. Will that box fit in the stock cargo tray? Also, since the batteries linked are 3.2 V do you wire them in series to get to 12?
cr117
cr117
PNW
Bronco, EV6
Yes, I’ve designed it to fit in the stock tray. Correct, it’ll be a 12V battery with the 4 cells wired in series.
cr117
cr117
PNW
Bronco, EV6
Feet attached. All that’s left is the lid and then I can wire everything together. Test fit was a success with plenty of room to spare.
Ford Bronco Custom Dual Battery Build IMG_5565
Chrome_Pony
Chrome
The Great Land
Looks fantastic! Any consideration to rewiring the factory 12V plug beside it to tap in to that system?
cr117
cr117
PNW
Bronco, EV6
My plan is to leave that one as is and add 1 or 2 more tapped into this system.
cynicalrider
First gen taco
Sub, love the box and the concept. Did you stick to the $600 budget?
cr117
cr117
PNW
Bronco, EV6
I only spent $184 for the battery. The smart shunt was another $70. I already had the boards and wires leftover from other projects.
cr117
cr117
PNW
Bronco, EV6
So... how much for your customers? lol
lol, there’s no way I’d want to produce this to sell with my tooling. The wiring and assembly was pretty easy, but the box construction takes a while using just a drill and saw. Using a 3D printer would make things much easier, but I don’t have one.
cr117
cr117
PNW
Bronco, EV6
Version 1.1: Rerouted the positive wire over to connect to a sub-module I built with a fuse block mounted. This fills out the rest of the space in that tray nicely and allows the safe connection of several terminals.
Ford Bronco Custom Dual Battery Build IMG_5599
Ford Bronco Custom Dual Battery Build IMG_5606
Ford Bronco Custom Dual Battery Build IMG_5613
