Cracked Upper Trailing Arm Mount
mattusmc
2018 Mustang GT PP2
Cracked a weld and bent the driver side upper trailing arm mount at Windrock this weekend. Time to reinforce the mounts I guess. This is on a 2023 2dr. Noticed after the third trail, the drive shaft would make contact with the fuel tank skid, the contact would get worse and worse. Found the axle to have pivoted to the driver rear. Put it in reverse and the axle straightened out enough I could limp it back to campground where we realigned the axle. Cleaned it off and discovered the crack and slight bend.
Ford Bronco Cracked Upper Trailing Arm Mount IMG_6577
Ford Bronco Cracked Upper Trailing Arm Mount IMG_6584
popo_patty
Caleb
Sacramento
Rock Krawler setup in the rear?
Mdsuits
05 f350, 68 bronco 89 samurai
Looks like the rk 4 link. I have a feeling this may become an issue.
mattusmc
mattusmc
2018 Mustang GT PP2
Yep RK 4 link, had it on for a while now. Lift,37s, etc. I’m just gonna drill and fill the crack and add some 1/4” plate with gussets to the frame and mount. Just sucks cause I’m gonna have to drop the tank again and reinforce the pass side for peace of mind lol.
87-Z28
Andy
BMW
Indeed. the 4 link setup transfers the lateral loading to the frame hard points. Especially for the upper links. The mounts need to be able to handle the extra loading that is not present with the 5 link since lateral loads are reacted by track bar. Using the factory hard points may be asking to much. Hopefully enough extra support can be welded in to remove this concern.
87-Z28
Andy
BMW
I would definitely do both sides and make sure you have some gussets oriented to stiffen the mounts laterally if possible.
Mdsuits
Just out of curiosity….you sure it wasn’t making contact before you took it out. This is a know issue with the rk 4-link. If you compress the passenger rear and drop the drivers side it steers the driveshaft and pinion yoke into the gas tank skid. I had to trim mine….plus use the rj sway bar to slightly limit flex.
Copperhorse73
Justin
Mooresville, NC
Do you have any pictures of how much you trimmed the gas tank skid ?
popo_patty
Caleb
Sacramento
So I’ve been looking at the second picture trying to find the crack you mentioned but I can’t see one. Are you talking about that frame divot with the split looking area? Because if so, we all have that. Here is mine for reference.
Ford Bronco Cracked Upper Trailing Arm Mount 6081513D-88F8-42AD-846D-2590E8822ACB
mattusmc
mattusmc
2018 Mustang GT PP2
Well looks like I need to dive deeper into it when I get it home. The axle is definitely shifting under load to the rear DS. Thought that was it, zoomed in on the picture and it looks jagged not a straight seam.
