Upper Control Arm Selection
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
Anything more than 1.5 inches, you should technically be changing the UCAs. Anything lower and assuming you are using 35s and NOT 37s, then the stock UCAs are just fine and are actually designed very, very well on the Bronco. As most have specified here, IF you have to add the UCAs, seeing as you are above 3 inches on lift - ICONs are the best for price point and joint quality.
Personally, I have gotten the Eibach Pro Lift kit (springs ONLY). This is about a 1-inch lift. I'm retaining my stock UCAs and then adding - Rear Trailing links (https://www.rockjock4x4.com/RJ-182400-101) and an Icon Track Bar (https://www.polyperformance.com/icon-21-ford-bronco-rear-adjustable-track-bar-kit).
Sometime next year, if I decide to go full Coilover setup, then I will upgrade my UCAs as well.
I recently installed a 1.5" lift kit (spacers) on my Badlands, and noticed at full droop the upper control arm contacts the coil spring. Do aftermarket UCA's have extra clearance to clear the coils?
Sitruc_btb
Curtis
Chandler, AZ
In my opinion the icons with the delta pro joint has the most available angle available, period. They offer tube steel or aluminum versions. For now, these are the best available and superior to a ball joint many setups use.
What's your take on ball joints vs uniballs? I understand uniballs are stronger, but will they last, since some of them arent sealed?
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I've had great luck with Camburg and Icon. Both offer tubular and billet.
Icon also has a nice adjustable Rear Trac Bar.
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
Don’t know but will know soon. Have 1” lift now and will be installing another 0.5” plus the Zone UCAs that will be here tmrw.
NEO Motorsport Garage
Roman
North Royalton, Ohio
www.neo-garage.com
2023 Bronco Raptor, 2022 F150 Raptor
It really depends where in the country you live and will drive the Bronco, and how aggressive you plan to use it.
Ball joints are great because they tend to be quiet and maintenance free and last longer due to that.
Uniball are much stronger and hold up to serious abuse longer but will need to be serviced almost on a weekly basis due to the complete open design and tend to squeak all the time.
ICON kind of solved the issue with the Delta Joint which is a mix of both, with a much stronger joint and being partially closed from the elements while offering the extra travel in the joint like a uniball.
Let me know if we can help get you a set of arms. We carry almost every arm out there, and always have 10-15% off just about all brands!
www.Neo-garage.com
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
I have Zone UCA on mine. No issues at all. Have a 3” lift and my bronco aligned perfectly!
Sitruc_btb
Curtis
Chandler, AZ
www.Neo-garage.com
Thanks for the tips. I live in AZ, the desert. Lots of dust, and sometimes some monsoons. It is my daily driver, so it's not getting abused, stressing components. Ill scope out the site, thanks!
Roman
www.neo-garage.com
Reach out anytime with any questions. If you don’t see exactly what you need (it’s hard to constantly upload every single item to the online store), send a message and we will get you the part for the best price!
Bluray1
Jose
08 Chevy Avalanche, 2023 C8 Corvette
what lift did you go with? what size tires you running?
Dubsesd
Andrew
CT
I have the Zone Adventure series 3” with stock 35”s
Bluray1
Jose
How’s the ride quality? Would you recommend that lift? I’m not going to be doing any off-roading, just want to put on 35”s and have a little lift.
