- First Name
- Curtis
- Joined
- Sep 16, 2021
- Threads
- 12
- Messages
- 996
- Reaction score
- 2,008
- Location
- Chandler, AZ
- Vehicle(s)
- 2022 Bronco Badlands
- Your Bronco Model
- Badlands
I recently installed a 1.5" lift kit (spacers) on my Badlands, and noticed at full droop the upper control arm contacts the coil spring. Do aftermarket UCA's have extra clearance to clear the coils?Anything more than 1.5 inches, you should technically be changing the UCAs. Anything lower and assuming you are using 35s and NOT 37s, then the stock UCAs are just fine and are actually designed very, very well on the Bronco. As most have specified here, IF you have to add the UCAs, seeing as you are above 3 inches on lift - ICONs are the best for price point and joint quality.
Personally, I have gotten the Eibach Pro Lift kit (springs ONLY). This is about a 1-inch lift. I'm retaining my stock UCAs and then adding - Rear Trailing links (https://www.rockjock4x4.com/RJ-182400-101) and an Icon Track Bar (https://www.polyperformance.com/icon-21-ford-bronco-rear-adjustable-track-bar-kit).
Sometime next year, if I decide to go full Coilover setup, then I will upgrade my UCAs as well.
