Cracked Instrument Cluster
BRBlue
Houston
Toyota Tundra
Has anyone else had this happen? The glass (plastic) in front of my speedometer has developed a vertical crack in the center from the bottom half way up to the top. Dealer won’t repair under warranty because “this type of thing just doesn’t happen so it must be from damage”. Ridiculous. 🤷🏽‍♂️
BroncoWTFAN
MachE FE & BL SAS 22
BRBlue
BRBlue
Houston
Toyota Tundra
PrepVet
North Central WI
A bunch.
Sorry no pics. It’s been at the dealer for 2 weeks.
For this or something else?
At any rate, this should still be covered by warranty. Fit and finish problems are part of the factory bumper to bumper.
BRBlue
BRBlue
Houston
Toyota Tundra
I’ve kept a running list of issues. Warranty is up in 500 miles so dropped it off to get all of the items fixed. This is one of them. I agree, warranty should cover this issue.
BRBlue
BRBlue
Houston
Toyota Tundra
Does it look like this? The screen on the bronco I had at the off roadeo was cracked
Yep. That’s it! Thanks for sharing.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Fight it. There is always the first person with a new or unknown issue. Someone was first with every other issue.
Tricky Mike
21 Bronco
My dealer wouldn't warranty my cracked airbag until I called Ford customer service and asked them to intervene. You might try that.
Redcobra
Tony
Massachusetts/Florida West Coast
2018 Expedition, 2020 Escape, 2010 Escape, 2008 S550, 2002 Tbird, 1930 Model A
Mine had 2 small cracks at the bottom and was replaced under warranty at 14,000 miles and two years old.
BRBlue
BRBlue
Houston
Toyota Tundra
Pictures?
Ford Bronco Cracked Instrument Cluster IMG_0300
Got it back from the dealer. Here’s a picture. Their position is that Ford will not replace the part. I have a call into Ford and received a message that “there is no program to replace the part”. Not sure how that has anything to do with a warranty. We’ll see where this goes but my gut tells me the dealer doesn’t want to hassle with pulling the dash, etc. to do the repair.
Redcobra
Tony
Cracks are almost identical
No vendor issue here………
flip
Phil
IN
www.ruxerparts.com
Fords
M2DZ-10890-A FFS, it's a $40.00 part. Unless it has impact marks from the outside, which it probably won't, it's likely an adhesive or plastic weld induced stress crack. Pick your poison, temp related or just general stress. Stress crack, when void of evidence of mechanical impact or chemical induced failure, can be covered (glass is a different beast but still has limited coverage if a structural failure below it is the cause and within coverage limits).
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
