Correct locations for factory fender emblems?
DemonGT
Dan
Wisconsin
2022 Badlands
Anyone know how to find the correct location for the factory fender emblems?
CalvinT
Calvin
Phoenix, AZ
Do any dealers near you have Broncos in stock? Go measure.
Subaru includes a template with their emblems. I don't know if Ford does or not. I know they don't include a template for the tailgate Bronco emblem.
DemonGT
DemonGT
Dan
Wisconsin
2022 Badlands
The previous owner removed the badlands emblems and put the bronco script logos on and the wife does not like them... 😐
SnowBronco
Canada
And what do you like?
MileHighCitizen
Al
Denver
Bronco 2D 2.7
Im gonna bet he likes his wife to be happy.
I wanted a blue Bronco....you can guess why it's Cactus Grey. Compromise on the things that don't matter so you can enjoy the things that do. My $.02
DemonGT
DemonGT
Dan
Wisconsin
2022 Badlands
Nailed it. 🙂
MileHighCitizen
Al
Denver
Bronco 2D 2.7
Question for G6 if you have a badlands non Sasquatch and you buy the tires do you change the emblem????????
Technically you would need a ~.5” suspension lift and the 4.7 gearing (4.46 in Badlands) then they would be the same if you added 35” tires. But Badlands has sway bar disconnect.
Not sure if that’s what you’re asking.
BroncoDave24
East Tennessee
'61 Falcon, '87 F150 XLT Lariat 5.0, '01 F350 7.3L, '24 WildTrak
If the old script Bronco badges were put in the correct place, you could put the Badlands sticker below it. IMHO It should look OK there.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Dontc4re
If you're asking how the make a SAS equivalent Badlands you'd need to add the following to make it a true SAS Factory equivalent
• 17” Black High Gloss-Painted Aluminum, with Warm Alloy Beauty Ring, Beadlock Capable Wheels
• 4.7 Final Drive Ratio with Electronic-locking Front and Rear Axle
• High Clearance Suspension
• High Clearance Fender Flares
Note: LT315/70R17 Mud-Terrain (M/T) Tires (35”)
Note: Position-sensitive Bilstein Shock Absorbers
Most of the parts are available as take-off for a lot less than Ford accessory prices, or you could buy better aftermarket parts for about the same cost as Ford accessory prices and come out ahead. All depends on how you intend to use the Bronco.
Upgrading the Badlands stock axles from 4.46 to the stock SAS 4.7 in all likelihood would not be worth the expense.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Ask your wife if she knows what a Rorschach test is. If she does, then let her stare at the Badlands badge and ask her what she sees. I predict she'll like the Script badges afterwards.
