Cheap modular bumper
Jb7
Woodstock ga.
Ram 1500 sport
I only had 14 clip on threaded nuts, so 7 on each side, 4 of them are at the locations where you are installing fog lights on each side, so you can easily change out fog lights without having to reach back and hold onto a std nut, the other three were along the top on each side where I have the yellow stickers…I think some people have gotten more than 14 threaded clip nuts in the box so I’m not sure where they stuck the other ones
jp925
Ventura
2023 Big Bend, 2006 STi, 1974 Bronco
I assume you've already looked at this video - which I think is the ebay version
Past that, sorry I can't help much more.
The eBay version is the Amazon version, the model
Number cross referenced across both sites.
jp925
Ventura
Ugh, mine came with 20…..
Ah interesting, I heard somewhere else they were different somehow - the ebay version was a single piece or something? Maybe that's just how it's packaged/shipped is different.
jp925
Ventura
I do recall there being another version that was one piece, but my box part number from Amazon, Lyam-731, is the part numbered listed for this eBay bumper which looks identical.
https://www.ebay.com/itm/325836112835
DrewMackin
Drew
Dripping Springs, TX
23 Tesla Model 3, 23 Bronco Heritage
Did you find a cheat sheet on what uses the threaded clips vs the nuts and bolts? I’m having a hell of a time trying to figure out where to use them.
I just had to keep messing around with them until I got it where I was able to access everything. It seemed I was shorted on the clips and only used four (two on each side) where you would put the fog lights. So my mounting bracket is only secured with two bolts, but it's definitely secure. It was not a fun process figuring it out.
FoxFour281
Kelly
Central Valley, CA
02 Mustang GT, 02 Expedition EB
Well it's on... I don't totally love the bumper. Save yourself some headache and get the speed nut clips from Ace or AutoZone. The supplied one are weak.
Those speed nut clips go on the inner brackets that support the ends and brackets that the big anchors sandwich.
When mounting the clone to the truck, I needed to use three washers on the bottom mount to level it out.
Ford Bronco Cheap modular bumper 20231226_164845
Ford Bronco Cheap modular bumper 20231226_115008
Ford Bronco Cheap modular bumper 20231226_113742
Ford Bronco Cheap modular bumper 20231226_114324
jp925
Ventura
This is interesting….. how man clips came with yours?
FoxFour281
Kelly
Central Valley, CA
jp925
Ventura
18 in the bag, plus 4 already installed.
I wonder if we could convince someone with this bumper to take it off and take some pictures of the mounting points
FoxFour281
Kelly
Central Valley, CA
It's fairly straightforward, I thought I took a picture of all the locations that needed the speed clips and what uses bolt/nut.
jp925
Ventura
You did, sorry, I don’t think I realized this was how the factory assembled it; thank you!
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Thank you, for anyone looking at this, you have to add it to your cart and then add the coupon code (which ebay lets you simply click on to apply) to get the $65 off. It doesn't show on the item page ;)
uknowhim21
New Jersey
2007 Lexus GX 470, 2024 Bronco Ordered
Looks like that coupon is no longer available.
