Changing Spark Plugs......
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So, I have a 2.7 and recently ordered the "gapped" plugs from Panda Motorworks :) (hoping to get better fuel economy.....)
Anyways, I keep getting labor quotes that are insane....Does anyone know of a step-by-step video that exists anywhere to show me how to do this? I do have the "magnetic" spark plug tool to secure it properly and also a TQ wrench. I just need a guide.....to make sure I get past all that wiring and connectors that area ll over the top of the engine.
Thanks in advance oh great forum!!! :) :please:
jsoa
Jose
Delaware
2024 Bronco 4dr
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Oh i saw that already - that's for the 2.3 not the 2.7. I did try scouring YT as well.....but maybe I missed something.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I saw that as well thank you. Just wanted to also see if there were any more with better camera angles and not ones that are "exploratory." It's just a mess under that hood.
Felix808
SRV CA
Now you did it. You made me go out into the cold garage :sneaky: First picture shows a big screwdriver pointing to the center coil pack middle red arrow as well. It shows the connection you will need to unplug bottom center arrow. It shows the nut/ stud you will need to remove top center arrow. once unplugged & nut/ stud removed pull the coil pack up & out and you will see the spark plug. Left & right arrows show location of the other two. Rinse & repeat.
Ford Bronco Changing Spark Plugs...... passenger coil pakcs
Screwdriver & arrow point to center coil pack. same procedure. Hard to see in this picture but there are 2 more 1 left one right. With the other videos you should be able to get the idea. HTH 🤠
Ford Bronco Changing Spark Plugs...... driver coil packs
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
hahahahahaha!!!! Youre the best bro!!! :)
HoosierDaddy
__ Eric
NW. Indiana
I know squat about either of these motors, but having seen a few spark plug threads pop up now, I've always wondered ...
Would you also benefit from indexing these plugs while you're at it? ... Assuming of course, that these plugs or motors even lend themselves to indexing the spark plugs....
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I did research this as well. And......"Indexing spark plugs on a 2.7L EcoBoost engine, typically found in Ford F-150 trucks, is generally not considered necessary as the performance gain is usually minimal and not worth the added effort; however, some enthusiasts may still choose to do it for potentially slightly improved combustion efficiency by aligning the spark plug electrode with the optimal intake valve position."
Although these plugs are specifically "gapped" from Panda Motorworks optimally.
popo_patty
Caleb
Sacramento
Curious for my own knowledge here. Is there any real benefit to the 1 step colder plugs on our motors? I have the FP tune but it didn’t recommend different plugs at all.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Especially if you have a tune :)
popo_patty
Caleb
Sacramento
Felix808
SRV CA
Thanks. I’m gonna steer away from them and stick to OEM. It’s time to replace mine anyway. I’m assuming Ford Performance designed their tune around the OEM plugs since they don’t recommend different ones.
Whipple does not mention changing plugs either 🤠
