Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
How much does it weigh? couldn't see it on the website.
About 10lbs lighter than stock hood. Not sure about specifics
Rydfree
Benny
Alabama
I did not weigh mine but that seems strange. I hung my stock hood on the wall with one hand and the Cervini's hood seemed a good bit heavier when installing. Most fiberglass hoods I have installed on other vehicles were heavier than the stock ones.
Rydfree
Benny
Alabama
Looks great, I assume going this route you have to go back to using the factory hood prop rod? I guess one could drill and tap the hood and put their own attach point for using gas shocks for lifting the hood?
From my experience using hood struts on fiberglass hoods I always made a plate from aluminum that was a few inches wide that I attached the strut ball mount to then riveted the plate to the hood. This spreads the weight over a larger area and keeps the fiberglass from cracking at the attachment point. I had struts on my stock hood but haven't gotten around to making them work with the Cervini's though. There is definitely enough room and a flat enough area on the bottom side to do this though.
Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
Cervinis told me 27lbs for their hood and I was under impression the stock hood was 35lbs. But could have been switched.
Rydfree
Benny
Alabama
You could be correct. I certainly did not weigh either of them. It just could have been the weight was more top heavy with the scoop on the fiberglass hood making it feel that way. I do know my stock aluminum hood started moving around a good bit at interstate speeds , even after adjusting the stops. The Cervini's is solid and closes with a thud :)
Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
Yes noticed that too. Solid for sure
Draughon
Daylon
Dallas
BMW 4-Series
That's actually much better than I expected - thank you! Does it come with a liner / sound deadener on the inside? How's the "floppiness / wobble" factor at highway speeds?
$1500 all in with paint and shipping. Just be prepared to wait 12 weeks. They are super backed up on painted items. It turned out perfect but if you aren’t willing to wait that long I believe they said they can ship the hood in 2-3 weeks and a couple people told me around $800 to paint local
Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
No sound deadener but I guess the rain guard kinda acts like one. There is no movement at all in the hood at high speeds. Much tighter than the stock hood
Speedlogix
Lisa
West Palm Beach, FL
2023 Bronco Heritage
Looks tough, nice build!
buzpro
Binky
Tacoma
Oh I meant your brush bar .... i couldn't find the weight on the website you posted
Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
Oh sorry. Honestly I don’t know exactly but it is not light. Maybe 60lbs if I had to guess
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
@Daxe44 When I called Cervini a few weeks ago, they told me 50lbs. So that conflicts with the 27lbs, you were told.
Daxe44
Daxe44
Dax
Tampa
22 Ford Bronco
I get it. I’m just telling you it seemed lighter when I picked it up than the oem hood. It’s definitely not 50lbs. I put it on myself
BSBuild
Brent
Omaha, NE
2023 Bronco Black Diamond
I love this hood!
Ford Bronco Cervinis Stalker Hood installed 1000005084
Redline Tuning
F-150
I’ve seen a few guys use hood struts with no problems. The holes aren’t there but using either a small self tapping screw or drilling a pilot hole is very easy
We have a package designed specifically for customers like you who have upgraded to an aftermarket hood that had our system for the stock hood. It consists of mounting hardware and new end fittings and is available here:
https://www.redlinetuning.com/product-p/21-11042-05.htm
Ford Bronco Cervinis Stalker Hood installed 21-11042-05-2t-jpg
There is no concern using our system on a fiberglass hood as we included special rivets that work great with fiberglass and Carbon fiber. We have been designing our systems to work with aftermarket hoods for over 20 years.
Ford Bronco Cervinis Stalker Hood installed 21-11042-02-6-jpg
We also have a system designed for customers who have an aftermarket hood and need the entire system:
https://www.redlinetuning.com/2021-Ford-Bronco-Aftermarket-Hood-QuickLIFT-PLUS-p/21-11042-02.htm
Ford Bronco Cervinis Stalker Hood installed 21-11042-02-2-
