Capable Front Bumper vs Heavy-Duty Modular Bumper
Hoofnmouth
mark
N ca
ford focus st
Shoot im just going to make one i like the shorty look.
JaxGtc
Check out build and price. All 3 bumpers are available on Outer Banks. This is one of the last things I'm trying to decide. I was planning on the modular bumper and brush bar and add fog lights later. Suddenly, no X plan happened and now I may want to skip the modular bumper to make up the price difference. I'll probably just stick with the bumper that comes with it.
Yes, according to the B&P, if the trim has a plastic bumper, you can have all 3, but if you start with a HD bumper, you cannot go with the capable. I assume the reason is that they are pretty much the same price and similarly "capable". So for the plastic crowd (Base, BB, OB, and WT) you can pretty much have your pick of the two upgrades - for a price of course. :)
Gr8Hortoni
Whitehall, Michigan
I would like to see the “Capable Bumper” with the end caps removed. Curious if it’s similar to the Rubicon “stubby” bumper when the caps and wings are removed. ??‍♂
Lifeliberty
Moonbeam👀
Columbus, OH
The modular comes on an ordered Bronco from factory, so you just have the modular bumper on your Bronco, I get that.
Since capable bumper is a DIO, does the Bronco come from the factory with the standard bumper, then dealer installs capable bumper, and you get to keep the standard bumper too?
dejones64
Dan
MN
Bronco 2-dr Black Diamond
They both do. HD mod just doesn’t detach like the Jeep ones do, the bottom part of the wing gets removed.
Does this look like the skid plates go pretty far back underneath?
rmc523
South Florida
2022 Bronco Wildtrak
What about the bar on the capable bumper? Some pics show a short bar with a winch attached, but I don't see that bar listed on B & P. The only one I see is the taller one for the modular bumper. I like the bar, but would prefer the built in fog lights.
What bar? The safari one? Don't know, I personally am not interested in that feature.
gentlemanbronco
Rick
ford fiesta 5.0
BD comes with the modular one, if I wasn't getting a BD I'd stick with the plastic bumper and go aftermarket.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Those are expensive fog lights.
Yeah... but it's Fog Lights... and the OEM switch... and the Harness... and dashboard/vehicle integration....
Just to cross reference things here. The Bronco Parts and Accessories Guide came out.
While it is a CGI image, the Bronco they picked for the cover is a Badlands rocking a bunch of accessories, including the "Capable Bumper."
My intention is to spec the Capable bumper on a Badlands, just for the OEM Fog functionality, and eventually replace the bumper with an aftermarket one when they become available.
https://www.bronco6g.com/forum/thre...es-guide-including-pricing-part-numbers.8249/
Ford Bronco Capable Front Bumper vs Heavy-Duty Modular Bumper Screen Shot 2020-11-03 at 11.30.46
gryphon1231
dj
Miami FL
na
Capable bumper is in B&P down under Accessories/Exterior/Bumpers Roof etc.
After market is the way to go if you are going to spend money on upgrading the bumper, unless you plan on having Ford install a winch for you.
Gr8Hortoni
Whitehall, Michigan
Has anyone seen the capable bumper with end caps removed?
Tonka1
Brad
Green Bay, Wisconsin
Jeep Wrangler Willys
My thought is to use the pre-wired overhead switches included in the mid package for aftermarket fogs.
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
Interestingly, you cannot add the "capable bumper" to the Badlands (I'd assume to BD as well), because when you add the "capable bumper" to the other trims, it removes the upgraded bash plates if you have optioned them. Since the bash plates are standard on the BD and BL, the B&P will not let you add the "capable bumper". Which seems silly, and something wrong with the configurator!
Gr8Hortoni
Whitehall, Michigan
I didn’t check BL, but BD can’t option the bumper, think you might run into similar on BL because they are both rocking the HD.
