Capable Front Bumper vs Heavy-Duty Modular Bumper
Bronco1951
Allan
Northville, MI
2020 Escape / 2 door Badlands
Yeah for me, I ruled out the HD Modular as soon as we realized that you lose the fog lights (and most likely the entire wiring). Then I saw this Capable bumper that did nothing but raise a bunch of unanswered questions... but one thing is for sure.. they want $1k for it and it still doesn't come with a rear metal bumper.
So for me, pretty sure that 1k or close to it will get me an aftermarket and "for that reason I'm out" :)
I'm still not sure what rear bumper you get when you order the HD Modular front bumper.
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
On BD, IDK about other trims, you get a steel rear bumper per the reference guide posted yesterday
I would guess the plastic rear
Bikeric
Tulsa
2022 Badlands LUX on 37's
Old thread resurrection, but I'm still getting the Modular Front bumper because there is no other way to get the bash plates.
Ford Bronco Capable Front Bumper vs Heavy-Duty Modular Bumper N675EGZ
rmc523
South Florida
2022 Bronco Wildtrak
Come on Ford, .....with order date fast approaching, how is a customer to decide on these two bumper options. Ford doesn't even tell you what material the "capable bumper" is made of and whether the fog lights come with it or not.
Being under an accessory, the dealer may have to paint this "capable bumper".
At least tell us the material its made of.
People that have seen it have said it's steel.
And the picture shows fog lights. So why is there a question as to whether or not it has fog lights?
da_jokker
Jeep Wrangler JKUR
I've always expected to pick up aftermarket bash plates or maybe even a set off a Badlands when the owner decides to upgrade.
FTBronco9
F-150
Why is everyone so concerned with fog lights? I’ve always had them but rarely use them. Is it more for off-road use to light the ground? Just curious.
FTBronco9
F-150
I don’t see how the capable bumper could have the end caps removed. Looks like one piece of plastic. Doesn’t look steel at all.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Conspicuity.
I like having fog lights to be seen by other drivers. (Not to see better myself.)
I explained this in another thread, but the short-of-the-long-of-it is that by adding additional lights that create a geometric closed shape (a square in this case with the headlights, or a triangle in the case of motorcycles), it makes it for other drivers to more naturally and quickly judge distance and closing speeds.... lessening the change someone will misjudge and pull out in front of you.
FTBronco9
F-150
Conspicuity.
That’s an interesting theory. Never would’ve thought about that.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Yeah, it's a well documented thing in the motorcycle community. Triangle or "T" of light is how it's known.
This is anecdotal, but I noted a precipitous drop in the amount of people pulling out in front of me, even if they had plenty of time, when I added lights to make a triangle to my primary motorcycle.
Two headlights on a car already provide some subconscious closing speed info to the observer (as the lights get further apart as they near), but adding at least one other light to create that closed geometric shape means the object is changing size in 2 dimensions, which is much easier for the mind to make sense of.
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
Conspicuity.
Plus as you get older any additional light helps. ?:geek:
FTBronco9
F-150
My brain hurts now. That’s way too much knowledge.
da_jokker
Jeep Wrangler JKUR
And I think the primary is not the Fog lights as much as the removal of the factory wiring and switch. If I knew 100% the fog light plug was just tucked up under there, I would opt for the Modular myself most likely.
