Cant get the KC lights covers off!
MadMan4BamaNATL
Ray
Atlanta
They can be tricky and a bit intimidating the first time you do it.
The key is to be gentle, but deliberate with your movements. Very carefully, reach behind and with a soft pinching movement, squeeze carefully. Make sure you support the front with your other hand. Being soft and gentle is key here. You might fumble about, don't worry. Rub the front a bit as you find the sweet spot with your other hand. They will harden up as you work it, this is normal and an indication you're doing it right. As they release, keep a soft, firm grip and slowly lower them down.
Congratulations. You've earned this. Now make sure you bask in the soft glow and soak up the beauty your persistence has revealed.
Dude……
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
This thread turned into everything we had hoped for, and then some.
Well done, B6G.
Draughon
Daylon
Dallas
BMW 4-Series
HA! I had the same issue. Know what I found out? I called KC and asked for help and you wouldn't believe what they told me...
You need one of these on your keychain.
From the top, hook it with the longer edge facing the rear of the light and the covers will pop right off.
Alternatively, throw some amber covers on 'em. That's what I did for my front bumper.
Ford Bronco Cant get the KC lights covers off! 1734704719305-q0
MadMan4BamaNATL
Ray
Atlanta
Baja Designs for the win, yet again. :sunglasses:
bradenrc
Braden
Eagle, ID
2024 Bronco Wildtrak
Mine came with the key chain referenced above and it makes it SO much easier to get them off.
NCWildtrack
Clay
Sanford
2022 Wildtrack
I would definitely look into adding more of them.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I can tell you, I'm one of those "first try success" guys that goes, oh you can't get these off?!? Pop! Well, I guess you weren't trying hard enough! Oh I know, you loosened it for me...
Then I never can get them off again. It's a curse! :LOL:
Sants
Berks County, Pa
4Runner, Highlander, Prius (I know, I know)
Ok guys just got a used wildtrak 2 door and want to change the color of the K.C. on the aftermarket lights . I can not get these damm covers off and I dont want to break them . I've tried prying and they yeild some on the sides but the top seems like it is screwed to the light or something.... anyone have any ideas???
Is there any rubbing from the brackets on the lower painted trim of the grill? I have this installed on mine and a little nervous because I have seen a user have issue.
Ok, I have to admit that lights that require a bottle opener have me intrigued.
Umichigan1
2022 2-Door Bronco
The smallest amount of C4 explosive, placed stratigically...
buzzcutt2
FL
